Zloi
| I need advice, multitasking goes out of synchronization |
Posted: Fri Oct 26, 2012 12:05 pm |
I try to blink two led's in multitasking manner, but things are getting out of control, after n first cycle LED's are no longer synchronized. I'm using unsigned arithmetic and timer overflow should not be a problem. my guess is that the source of the error is IF conndition and > operator.
Can someone give me advice?
Here is code snippet,
#include <18F4620.h>
#device *=16
#fuses HS,NOWDT,NOPROTECT,NOLVP,BROWNOUT
#use delay(crystal=10Mhz, clock=40Mhz)
#use rs232(baud=57600, xmit=PIN_C6, rcv=PIN_C7, parity=N, bits=8, ERRORS)
#USE FAST_IO (ALL)
#include <string.h>
#define RedTimeToggle 500
#INT_TIMER0
void One_mS_Timer(void){
set_timer0(Timer0IntCnt);
Int0Cnt++;
if(Int0Cnt>19){
Int0Cnt=0;
Mills++;
struct {
unsigned int16 Old_Red_Mills;
} Left,Right;
unsigned int16 CalcElapsedTime(unsigned int16 MillsC,unsigned int16 OldMills){
unsigned int16 calc;
calc=MillsC - OldMills;
return (calc);
void LeftStartCondErr(){
if (CalcElapsedTime(Mills,Left.Old_Red_Mills) > (unsigned int16)(RedTimeToggle)){
printf("Left=%lu\r\n",Mills-Left.Old_Red_Mills);
printf("Mils=%lu\r\n"Mills);
Left.Old_Red_Mills=Mills;
if (input_state(LR)){
output_low(LR);
else{
output_high(LR);
void RightStartCondErr(void){
if (CalcElapsedTime(Mills,Right.Old_Red_Mills) > RedTimeToggle){
Right.Old_Red_Mills=Mills;
if (input_state(RR)){
output_low(RR);
else{
output_high(RR);
void main(void){
main:
disable_interrupts(GLOBAL);
SystemInit();
OutputInit();
SystemVariableInit();
FlushBuffers();
set_pwm1_duty(514);
enable_interrupts(INT_RDA);
printf("\r\n Running....\r\n");
output_low(PIN_A1);
Mills=0;
LoopTime=Mills;
Right.Old_Red_Mills=Left.Old_Red_Mills=Mills;
while (true){
LeftStartCondErr();
RightStartCondErr();
Here is the Printout:.
Mils=56135
Left=501
Mils=56638
Left=193 -> passed to the comparison condition
Mils=56833
Left=501
Mils=57336
Left=501
Mils=57839
Left=501 |
Posted: Fri Oct 26, 2012 1:18 pm |
Unfortunately,what you post, is a messy bit of tatty code, missing vital parts, and too large for debugging. But some comments:
Remember your printf's,will take about 4mSec.
Remember anything reading or writing an int16, which is updated in an interrupt, needs to _disable_ the interrupt, read/write the value, and then re-enable the interrupt. Otherwise if the value updates between one byte being used and the other, the results _will_ be wrong. Then is is even worse with something slow like a printf..... |
Zloi
Posted: Fri Oct 26, 2012 4:10 pm |
| Ttelmah wrote: | Unfortunately,what you post, is a messy bit of tatty code, missing vital parts, and too large for debugging.
I agree with the comment, program has about 800 lines of code and counting, for purposes of readability I did not want to post everything.
problem with LEDs haunted me for days.
| Ttelmah wrote: |
But some comments:
printf were there just for "debugging"...
I tried with disabling interrupts, but without positive result.
btw this is good advice with guarding int6,32 by disabling interrupts.
In the end I set up a free timer3 in main,
void GetTime(void){
if(get_timer3()>1249){
set_timer3(0);
Mills++;
So far everything working as expected.
Best regards |
