1khz PWM
IceMetal
1khz PWM
PostPosted: Wed Oct 24, 2012 11:52 am     Reply with quote
How can I get to 1Khz PWM with this chip? the most I can get is 50hz and I had try many combinations, do I need an external crystal?
#include "16F88.h"
#fuses NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
#use delay(clock = 4000000)
main()
int8 value_adc;
setup_adc_ports(sAN1);
setup_adc(ADC_CLOCK_DIV_16);
set_adc_channel(1);
while(1){
value_adc = read_adc();
setup_ccp1(CCP_PWM);  // Configure CCP1 as a PWM
setup_timer_2(T2_DIV_BY_1, 150, 1);      // 50 Hz
set_pwm1_duty(value_adc);                    // var duty cycle
PostPosted: Wed Oct 24, 2012 12:10 pm     Reply with quote
See this thread which has the PWM frequency formula:
http://www.ccsinfo.com/forum/viewtopic.php?t=17993
The two values (other than crystal frequency) which control PWM
frequency are the PR2 value and the pre-scaler.
IceMetal
PostPosted: Wed Oct 24, 2012 12:23 pm     Reply with quote
                      Crystal Frequency
PWM Freq  = -----------------------------------------
                  (PR2 + 1) * (Timer2 Prescaler) * 4
                      4000000
                  (150 + 1) * (1) * 4
PWM Freq  =  6622.51Hz
but according to that I should get 6.6Khz, and I'm getting 50hz
PostPosted: Wed Oct 24, 2012 12:58 pm     Reply with quote
You don't have an oscillator fuse, so the compiler will default to using
the RC fuse, which requires an external resistor and capacitor.
Do you have those components installed on the OSC1 pin ? If so,
what are their values ?
How are you testing this project ? Is this a simulator project ?
Just the fact that you don't have an oscillator fuse makes me
think there is no hardware board.
Also, you don't need to call setup_ccp1() and setup_timer_2() inside
the while() loop. You only need to call them one time, above the loop.
See this example program:
http://www.ccsinfo.com/forum/viewtopic.php?t=40007&start=1
IceMetal
PostPosted: Wed Oct 24, 2012 1:38 pm     Reply with quote
I have the hardware set but I dont have anything on OSC1 or OSC2 pin, would I be able to get 6.6Khz without external crystal?
here is a picture of the output
PostPosted: Wed Oct 24, 2012 1:51 pm     Reply with quote
Add the INTRC_IO fuse to your #fuses statement. Then the PIC will
run at 4 MHz from the internal oscillator and you will get better results
from your tests.
IceMetal
PostPosted: Wed Oct 24, 2012 1:55 pm     Reply with quote
from your tests.
Thank you!!! it works!! Very Happy
