arthurlmiranda
[working with hold_regs, and modbus rs485] problem |
Posted: Fri Oct 19, 2012 8:55 am |
Hello guys, this is my first post here.
I'm doing a simple test with modbus rs485. I have a button in a slave that I press it and the slave counts and the master should read this number...
My problem is the master get the right data from slave, I don't know if i have to use holding registers or input regs.
The sample ex_modbus_slave.c use some holding regs but I can't compile with them for example if I use 0x8800 i get this error (n#45) subscript out of range.
My ccs version IDE 4.078.
I'm simulating this on proteus.
My simulation with the slave address is working fine, the slave undertands that the message is for it.
Probably I won't have access to internet until monday morning.
Sorry for bad English, I'm from brazil.
Masters Code
#include <18F4550.h>
#fuses HS, NOWDT, NOLVP, NOBROWNOUT, NOPROTECT, PUT
#use delay(clock=20M)
#define MODBUS_TYPE MODBUS_TYPE_MASTER // MODBUS_TYPE_MASTER or MODBUS_TYPE_SLAVE
#define MODBUS_SERIAL_INT_SOURCE MODBUS_INT_EXT //interrupcao externa mas nao estamos usando os pinos que tem interrupcao
#define MODBUS_SERIAL_BAUD 9600 //Valid baud rate for serial
#define MODBUS_SERIAL_RX_PIN PIN_c6 //Valid pin for serial receive
#define MODBUS_SERIAL_TX_PIN PIN_c7 //Valid pin for serial transmit
#define MODBUS_SERIAL_ENABLE_PIN PIN_c4 //Valid pin for serial enable, rs485 only
#define MODBUS_SERIAL_RX_ENABLE PIN_c5 //Valid pin for serial rcv enable, rs485 only
#define MODBUS_SERAIL_RX_BUFFER_SIZE 64 //Size of the receive buffer
#define MODBUS_SERIAL_INT_SOURCE MODBUS_INT_RDA //Tipo de interrupção(assincrono) pro rs
#include "modbus.c"
#define MODBUS_SLAVE_01_ADDRESS 0xF5
#define MODBUS_SLAVE_02_ADDRESS 0xF6
void read_all_holding()
if(!(modbus_read_holding_registers(0xF5,0x0001,8))) // should I use 0 or 8?
int i;
printf("Data: ");
/*Started at 1 since 0 is quantity of coils*/
for(i=1; i < (modbus_rx.len); ++i)
printf("%X ", modbus_rx.data[i]);
printf("\r\n\r\n");
printf("<-**Exception %X**->\r\n\r\n", modbus_rx.error);
void read_all_input_reg()
printf("Input Registers:\r\n");
if(!(modbus_read_input_registers(0xF5,0x0003,8))) // should I use 0 or 8?
int i;
printf("Data: ");
printf("\r\n\r\n");
int i;
// 2 test to receive the data. Using the sample from ex_modbus_master
printf("\rreading holding");
read_all_holding();
delay_ms(1800);
read_all_input_reg();
printf("\rreading input reg");
delay_ms(1800);
// 2 test to receive the data. Using the samples from modbus.c
modbus_read_holding_registers(0xF5,0x0001,8);// should I use 0 or 8?
delay_ms(1800);
modbus_read_input_registers(0xF5,0x0003,8); // should I use 0 or 8?
delay_ms(1800);
} //whie
}//main
Slave
#use rs232(baud=9600, xmit=PIN_B1, rcv=PIN_B0, stream=PIC, errors)
#define MODBUS_TYPE MODBUS_TYPE_SLAVE // MODBUS_TYPE_MASTER or MODBUS_TYPE_SLAVE
#define MODBUS_SERIAL_INT_SOURCE MODBUS_INT_EXT //Source of interrupts (MODBUS_INT_EXT,MODBUS_INT_RDA,MODBUS_INT_RDA2)
#include "modbus.c"
#define MODBUS_ADDRESS 0xF5
int8 coils = 0b00000101;
int8 inputs = 0b00001001;
int16 hold_regs[] = {0x8800,0x7700,0x6600,0x5500,0x4400,0x3300,0x2200,0x0001};
int16 input_regs[] = {0x0003, 0x0004};
int16 event_count = 0;
int8 *data;
int i=0;
modbus_init();
printf ("slave 0xF5") ;
while(!modbus_kbhit())
if((modbus_rx.address == MODBUS_ADDRESS))
if(input(pin_D4)==1){
i++;
data=i;
hold_regs[0x8800]=data;// test to use with read holding registers
input_regs[0x0003]= data;// test to use with read input registers
printf("\r button pressed %ld times ",data);
if(modbus_rx.func == FUNC_READ_HOLDING_REGISTERS)
modbus_read_holding_registers_rsp(MODBUS_ADDRESS,(modbus_rx.data[3]*2),hold_regs+modbus_rx.data[1]);
modbus_read_input_registers_rsp(MODBUS_ADDRESS,(modbus_rx.data[3]*2),input_regs+modbus_rx.data[1]);
Thank You guys |
Mike Walne
Posted: Fri Oct 19, 2012 11:00 am |
Quote: | I'm simulating this on proteus. |
This is a CCS forum not a proteus one.
Proteus is bad news, it's so full of bugs you're wasting your time with it.
Eventually you have to get real hardware to work in the real world.
Start with real hardware.
I can't (no refuse to) help with ISIS / Proteus.
Mike |
Joined: 01 Jul 2010 Posts: 9174 Location: Greensville,Ontario
Posted: Fri Oct 19, 2012 11:39 am |
I have to 'second' Mike's response ! Please read PIC101 at the top of this forum.
As Mike said Proteus is FULL of bugs, errors and faulty DRCs. You can't possibly expect anyone to 'fix' your code when your 'running' on a real bad 'simulator'.
The only simulator I run is real hardware in the real world.NO simulator,that I know of, will create EMI,welding spikes, cell phone interferenc,power dips,noisey Vcc,bad solder joints, pins swapped,etc.
Buy a PIC, a white breadboard and some 22ga solid wire.For less than an hour's worth of total frustration you can buy all the real hardware you need and NOT be disappointed!
And... you'll get lots of help here as well.
hth
jay |
Mike Walne
Posted: Fri Oct 19, 2012 2:37 pm |
Thanks jay.
Nice to get some support.
Mike |
arthurlmiranda
Posted: Wed Oct 24, 2012 7:22 am |
ok but no one who knows how to use modbus can tell me if I'm doing something really stupid?
where I work here I can only simulate this, I don't know when my boss will buy PIC and etc... |
Posted: Wed Oct 24, 2012 11:35 am |
Yes, there is something wrong. You should look closely at your
pin assignments below:
Look at the 18F4550 data sheet and see what the functions and
capabilities of those pins are, and then look what you are trying
to use them for. Also, look in all the CCS modbus files and
notice what pin they assign to those constants.
Also you have changed the case of the pin on each pin constant.
This is not the same as the All Caps case that's used in the CCS .h files.
CCS is a rare compiler that by default, it ignores the case. If you
change the case of compiler constants in other compilers, you will get
"undefined identifier" errors. It's a bad habit to change the case. |
