Communicate PIC to PIC
fazreen
PostPosted: Thu Oct 18, 2012 8:24 am     Reply with quote
Why this tx and rx from PIC to PIC can't communicate ? Someone can help me...
This program for transmitter:
#include <18F4550.h> // PIC18F4550 HEADER FILE
#fuses XT, PUT, HS,NOWDT, NOLVP, NOBROWNOUT // EXTERNAL CLOCK, NO WATCH DOG TIMER, NO LOW VOLTAGE PROGRAMMING
//#include <utility.c>
#use delay (clock=20M)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7) // 4 MHZ CRYSTAL
#define BUTTON1 PIN_B0 // PRESET BUTTON 1
#define BUTTON2 PIN_B1 // PRESET BUTTON 2
#define LED1 PIN_B6 // LED 1
#define LED2 PIN_B7 // LED 2
#define LED3 PIN_D0 // LED 3
#define LED4 PIN_D1 // LED 4
void main ()
set_tris_b(0x01); // SET ALL PORT 0-b3 AS INPUT b4-b7 OUTPUT
//set_tris_d(0x00);
set_tris_c(0x11); // SET ALL PORT d AS OUTPUT PORT(0b 0000 0000)
output_b(0x00);
while(true)
   putc('a');
   delay_ms(10);
   //putc('b');
   //delay_ms(1000);
AND this is for receiver:
#include <18F4620.h> // PIC18F4550 HEADER FILE
#fuses XT, PUT, HS, NOWDT, NOLVP, NOBROWNOUT // EXTERNAL CLOCK, NO WATCH DOG TIMER, NO LOW VOLTAGE PROGRAMMING
void main ()
//set_tris_d(0x00);
output_b(0x00);
while(true)
   char data;
   while(true) // always repeat program
     if (kbhit())
     data=getc();
     if (data='z') // when press button 1
        output_high(LED2);
        output_low(LED1);
        //output_low(PIN_A3);
       output_low(LED2);
       output_high(LED1);
       //ouptut_low(PIN_A3);
Mike Walne
PostPosted: Thu Oct 18, 2012 11:15 am     Reply with quote
Can you get either of your boards to communicate with a PC?
Mike
PostPosted: Thu Oct 18, 2012 12:41 pm     Reply with quote
1) add 'errors' to the use rs232(.....) lines,needed to keep the UART from 'freezing'.
2) get rid of set_tris....() lines, let the compiler automatically handle this
3) have you proved the LEDs function correctly? maybe in backwards?
4)do you have max232 or equal chips in the UART xmt/rcv lines?
5)do you have a common ground between the PICs?
6)you xmt only 'a' or 'b' but only test for a 'z', so how do you know it's not working ?
hth
jay
Mike Walne
PostPosted: Thu Oct 18, 2012 2:55 pm     Reply with quote
Another thought:-
Is this an ISIS simulation or real hardware?
Mike
fazreen
;0
PostPosted: Thu Oct 18, 2012 9:56 pm     Reply with quote
its working thank you
tzehow_90
View user's profile Send private message Send e-mail MSN Messenger
atten to fazreen...
PostPosted: Tue Mar 05, 2013 1:28 pm     Reply with quote
I am new in uart... can you post the full program that sucessful run?? and the connection??
Mike Walne
PostPosted: Tue Mar 05, 2013 2:54 pm     Reply with quote
I sincerely hope fazreen does not.
You will learn nothing if he does.
This is a help forum, not a do it for you one.
If you really want to become good with uarts I suggest:-
1) You start by using the CCS examples to communicate with a PC.
2) Progress from there.
3) If (when) you get stuck ask for specific help.
4) Read the forum guidelines.
Mike
PS My comments here also apply to your post on another thread.
Others and I have provided enough hints here to show you a way.
tzehow_90
thx
PostPosted: Thu Mar 07, 2013 7:53 am     Reply with quote
Mike
thx
