sht71 code problem
andys
sht71 code problem
PostPosted: Thu Oct 11, 2012 6:21 am     Reply with quote
I tried to connect sht75 sensor with pic but i get a strange error.
(I use the driver for sht75 which i found from the web) and the dspic30f2010.
The error which I receive is :
*** Error 128 "sht75.c" Line 7(1,13): A #DEVICE required before this line
Is anyone who know how to fix it ?
The code which I use is:
#include <30F2010.h>
//#fuses HS,NOWDT,PUT,NOPROTECT,NOLVP
#fuses HS,NOWDT,NOPROTECT
#include<lcd.c>
#include<sht75.c>
 float restemp, truehumid;
 sht_init();
  sht_rd (restemp, truehumid);
  lcd_gotoxy(1,1);
  printf(lcd_putc, "Temp : %3.1f %cC   ", restemp, 223);
  printf(lcd_putc, "\nRH   : %3.1f %%   ", truehumid);
  delay_ms(500);        //delay 500 ms between reading to prevent self heating of sensor
and the sensor driver:
#define sht_data_pin   PIN_C13
#define sht_clk_pin    PIN_C14
//***** Function to alert SHT75 *****
void comstart (void)
 output_float(sht_data_pin);  //data high
 output_bit(sht_clk_pin, 0);  //clk low
 delay_us(1);
 output_bit(sht_clk_pin, 1);  //clk high
 delay_us(1);
 output_bit(sht_data_pin, 0); //data low
 delay_us(1);
 delay_us(2);
 delay_us(1);
 delay_us(1);
//***** Function to write data to SHT75 *****
int1 comwrite (int8 iobyte)
 int8 i, mask = 0x80;
 int1 ack;
 //Shift out command
 delay_us(4);
 for(i=0; i<8; i++)
   if((iobyte & mask) > 0) output_float(sht_data_pin);  //data high if MSB high
   else output_bit(sht_data_pin, 0);                    //data low if MSB low
   delay_us(1);
   delay_us(1);
   mask = mask >> 1;                                    //shift to next bit
 //Shift in ack
 delay_us(1);
 ack = input(sht_data_pin);   //get ack bit
 delay_us(1);
 return(ack);
//***** Function to read data from SHT75 *****
int16 comread (void)
 int8 i;
 int16 iobyte = 0;
 const int16 mask0 = 0x0000;
 const int16 mask1 = 0x0001;
 //shift in MSB data
 for(i=0; i<8; i++)
   iobyte = iobyte << 1;
   delay_us(1);
   if (input(sht_data_pin)) iobyte |= mask1;  //shift in data bit
   else iobyte |= mask0;
   delay_us(1);
 //send ack 0 bit
 delay_us(1);
 delay_us(2);
 delay_us(1);
 //shift in LSB data
 for(i=0; i<8; i++)
   delay_us(1);
   delay_us(1);
 //send ack 1 bit
 delay_us(1);
 delay_us(2);
 return(iobyte);
//***** Function to wait for SHT75 reading *****
void comwait (void)
 int16 sht_delay;
 delay_us(1);
 for(sht_delay=0; sht_delay<30000; sht_delay++)  // wait for max 300ms
   if (!input(sht_data_pin)) break;              //if sht_data_pin low, SHT75 ready
   delay_us(10);
//***** Function to reset SHT75 communication *****
void comreset (void)
 int8 i;
 delay_us(2);
 for(i=0; i<9; i++)
   output_bit(sht_clk_pin, 1);  //toggle clk 9 times
   delay_us(2);
   delay_us(2);
 comstart();
//***** Function to soft reset SHT75 *****
void sht_soft_reset (void)
 comreset();           //SHT75 communication reset
 comwrite(0x1e);       //send SHT75 reset command
 delay_ms(15);         //pause 15 ms
//***** Function to measure SHT75 temperature *****
//int16 measuretemp (void)
int16 measuretemp ()
 int1 ack;
 int16 iobyte;
 comstart();             //alert SHT75
 ack = comwrite(0x03);   //send measure temp command and read ack status
 if(ack == 1) return;
 comwait();              //wait for SHT75 measurement to complete
 iobyte = comread();     //read SHT75 temp data
 return(iobyte);
//***** Function to measure SHT75 RH *****
int16 measurehumid ()
//int16 measurehumid (void)
 int1 ack;
 int16 iobyte;
 ack = comwrite(0x05);  //send measure RH command and read ack status
 return(iobyte);
//***** Function to calculate SHT75 temp & RH *****
void calculate_data (int16 temp, int16 humid, float & tc, float & rhlin, float & rhtrue)
 float truehumid1, rh;
 //calculate temperature reading
 tc = ((float) temp * 0.01) - 40.0;
 //calculate Real RH reading
 rh = (float) humid;
 rhlin = (rh * 0.0405) - (rh * rh * 0.0000028) - 4.0;
 //calculate True RH reading
 rhtrue = ((tc - 25.0) * (0.01 + (0.00008 * rh))) + rhlin;
//***** Function to measure & calculate SHT75 temp & RH *****
void sht_rd (float & temp, float & truehumid)
 int16 restemp, reshumid;
 float realhumid;
 restemp = 0; truehumid = 0;
 restemp = measuretemp();    //measure temp
 reshumid = measurehumid();  //measure RH
calculate_data (restemp, reshumid, temp, realhumid, truehumid);  //calculate temp & RH
//***** Function to initialise SHT75 on power-up *****
void sht_init (void)
 comreset();    //reset SHT75
 delay_ms(20);  //delay for power-up
andys
sht71 code problem
PostPosted: Thu Oct 11, 2012 2:23 pm     Reply with quote
No respond yet?
PostPosted: Fri Oct 12, 2012 12:50 am     Reply with quote
Are you compiling from CCS, or using MPLAB as a front end?.
If the latter, then it is the old MPLAB problem, that you _must not_ put include files into the 'source files' section of the project. They must be put into the 'header files' section. Otherwise MPLAB tries to compile the files, and (for instance) your sht75 file, won't compile on it's own.
andys
sht71 code problem
PostPosted: Fri Oct 12, 2012 5:00 am     Reply with quote
I used the MPLAB v.8.85.
This is not a new version ?
PostPosted: Fri Oct 12, 2012 6:00 am     Reply with quote
It is not a problem about MPLAB being old, but it is a problem that we know is there for a long time. So, 'old problem' as in 'has always been there'.
There is also MPLAB 8.87, but 8.85 is fine.
The problem is not in your version of MPLAB, but in how MPLAB works.
In MPLAB there is a 'Project' screen, open this through menu View/Project.
In this Project screen there is a section called 'Source Files'.
Now, MPLAB will try to compile all *.c files in this list and that is where the CCS compiler fails. Only the file main.c should be in this list, remove all other *.c files like your sht75.c
Good luck.
