signal phase dimmer code
Goto page 1, 2  Next
lindoudaM2
PostPosted: Wed Oct 10, 2012 3:56 pm     Reply with quote
My code works well in ISIS simulation but in reality-show it's not same. I want to control dimming light with a triac.
Someone help me please to correct my code.
#include <16F877A.h>
#fuses XT, NOWDT, NOPROTECT, PUT, NOLVP
byte x;
void init ()
setup_adc_ports(RA0_ANALOG);
setup_adc(adc_clock_div_2);
set_adc_Channel(0);
setup_ccp1(ccp_pwm) ;
setup_timer_2 (T2_Div_by_1,255,1);
setup_timer_1(T1_internal);
SET_TRIS_B(0xFD);
#int_ext
void ext_isr()
if(input (pin_B0)  )
  ext_int_edge(H_to_L);
init();
while (1)
   enable_interrupts(INT_EXT);
   delay_ms (10);
   x=read_adc();
   set_pwm1_Duty(x);
   delay_ms (10);
   disable_interrupts(INT_EXT);
   Clear_interrupt(INT_EXT);
Gabriel
PostPosted: Wed Oct 10, 2012 4:14 pm     Reply with quote
why not use RB int instead of Ext int?
it trigger on change... so you dont have to change the direction of the trigger signal....
I would also move these:
out of the while loop and reverse the order...
i believe... that once the ISR triggers it automaticaly clears the interrupt flag... so you dont have to doit manually....
your crystal fuse is XT... yet you are declaring a 20MHz clock...
Try HS better...
just my 2 cents..
G
CCS PCM 5.078 & CCS PCH 5.093
lindoudaM2
PostPosted: Wed Oct 10, 2012 4:27 pm     Reply with quote
I don't understand what you mean by that, not use RB int is that i did wrong (int_ext).
Mike Walne
PostPosted: Wed Oct 10, 2012 4:44 pm     Reply with quote
Three things.
1) Forget ISIS. It's so full of bugs you're wasting your time and ours.
2) Describe your hardware, or show us a schematic.
3) Tell us what's happening that's not what you expect.
Mike
lindoudaM2
PostPosted: Wed Oct 10, 2012 5:13 pm     Reply with quote
Mike Walne wrote:
Three things.
Mike
I am trying to conceive a single-phase triac dimmer controlled by the PIC 16F877A. My problem is at the level of the load (lamp) there are no variation of brightness despite the PWM signal varies appropriately.
PostPosted: Thu Oct 11, 2012 12:51 am     Reply with quote
First of all, don't start a new thread for the same project every time. This is already your 4th thread for this dimmer project.
Keeping it all together makes it easier for everyone to see what has already been discussed.
I think you made a major design flaw. A triac is not to be connected to a PWM output. PWM will generate a lot of trigger pulses but, by it's nature, the triac will stay enabled once it is triggered till the current flowing through it drops to zero. So, after the first PWM pulse, the triac will enable and then nothing changes until the next mains line zero crossing.
I suggest you do some more reading into the subject. Microchip has some really nice Application Notes on their website for this.
Mike Walne
PostPosted: Thu Oct 11, 2012 8:25 am     Reply with quote
Like ckielstra says, you need to think about how you're going to trigger the triac.
So far you've not shown us anything about your hardware.
When your hardware is sorted, the triac part of the software goes:-
1) Wait for zero crossing.
2) Wait for a time set by ADC output (0 - 10ms for UK mains).
3) Trigger triac.
4) Loop back to 1, assuming triac will turn off close to next zero crossing.
Mike
gpsmikey
PostPosted: Thu Oct 11, 2012 2:37 pm     Reply with quote
All of this is assuming we are talking a resistive (tungsten) light or something similar for dimming. If it is an inductive (fluorescent or something else), then it opens a whole new can of worms. Usually in this kind of project, it is a resistive load, but every now and then, after many posts, the OP happens to mention the fact it is an inductive load or something else.
mikey
mikey
PostPosted: Fri Oct 12, 2012 10:11 am     Reply with quote
triac dimmer
1- PWM is NOT the way to trigger a triac
2- you need to sense each zero crossing of the AC power waveform
and trigger at an appropriate phase angle offset from zero - to get phase control
3-study triac phase control , then design a circuit and ONLY THEN create your control code.
PostPosted: Fri Oct 12, 2012 12:21 pm     Reply with quote
Also you need to look at some real AC waveform.
Real mains, especially when triacs are involved anywhere nearby, does not resemble a sinusoid at all closely. This is a typical example of where Proteus will give very erroneous results.
This is why there are quite complex IC;s around to make zero crossing detectors, since it is not a simple thing to do...
lindoudaM2
PostPosted: Fri Oct 12, 2012 4:19 pm     Reply with quote
Hello
I ameliorated my code and here is it
wish that everything will be fixed Smile
#include<16F877A.h>
#use delay (clock =20000000)
#fuses HS,NOWDT, NOPROTECT,  PUT, NOLVP
byte x;
void init ()
setup_adc_ports(ALL_ANALOG);
setup_adc(ADC_CLOCK_DIV_2);
Set_adc_channel(0);
setup_CCP1(CCP_PWM);
set_tris_b(0xFE);
#int_ext
void ext_isr()
if (input(pin_B0))
init();
while (1)
   delay_ms (10);
   x=read_adc();
   set_pwm1_Duty(x);
   clear_interrupt(INT_EXT);
   delay_ms(10);
gpsmikey
PostPosted: Fri Oct 12, 2012 6:59 pm     Reply with quote
"ameliorated" - good grief - i'd never heard that word before so had to look it up. Obviously others have not heard of it before either - they claim "Ameliorate is currently in the top 1% of lookups and is the 104th most popular word on Merriam-Webster.com." - my learning for today is complete - time to relax :-)
mikey
mikey
Mike Walne
PostPosted: Sat Oct 13, 2012 3:41 am     Reply with quote
So, does it now work?
Mike
PostPosted: Sat Oct 13, 2012 7:31 am     Reply with quote
Mike
I guess not because his interrupt is doing nothing, he is not using any synchronization to the AC waveform and the PWM output that was discouraged is still there...
I don't mind to help, but what is the question?
PostPosted: Sat Oct 13, 2012 9:09 am     Reply with quote
I'd be very hesitant to use the word ameliorated, since it implies 'better'.
It's like posting saying "I've fixed my code, but it still doesn't work". One part or the other of the statement is untrue....
Goto page 1, 2  Next
Page 1 of 2
