rikotech8
Joined: 10 Dec 2011 Posts: 376 Location: Sofiq,Bulgariq
instruction time? |
Posted: Fri Oct 05, 2012 6:15 am |
What is the formula calculating the time needed for one instruction? |
Mike Walne
Posted: Fri Oct 05, 2012 6:19 am |
I'm assuming you mean assembler instructions not 'C'.
By and large, instructions take one instuction cycle, except jumps which take two. One instruction cycle being four oscillator clock cycles.
Mike |
Joined: 01 Jul 2010 Posts: 9186 Location: Greensville,Ontario
Posted: Fri Oct 05, 2012 6:31 am |
ie: if using a 4MHz xtal each instruction will take 1usec, except jumps as Mike noted.
if you refer to the datasheet for your PIC there's an entire section that details the 'instruction set'.
hth
jay |
Posted: Fri Oct 05, 2012 9:01 am |
The MPLAB IDE has a Stopwatch function which I often use when I want to time a sequence of instructions. This also works in the Simulator, so no actual hardware is needed. |
