Help with glcd_text57() function in GLCD.c
vinay
PostPosted: Mon Oct 01, 2012 2:52 am     Reply with quote
I am using glcd_text57() function to display text on an 128X64 Ampire GLCD(ks1080 based), but some of the pixels are missing. I have attached the driver program(I have made changes to CS1 and CS2 as active low in the driver) and the main() function that I am using, also I have attached a screenshot of the output I am getting.
compiler version 4.114
Pls suggest any corrections to get proper output.
////                           GLCD.C                                ////
void glcd_writeByte(char chip, BYTE data)
   if(chip == GLCD_CS1)       // Choose which chip to write to
      output_low(GLCD_CS1);
      output_low(GLCD_CS2);
   output_high(GLCD_CS1);      // Reset the chip select lines
   output_high(GLCD_CS2);
// Purpose:       Reads a byte of data from the specified chip
// Ouputs:        A byte of data read from the chip
BYTE glcd_readByte(BYTE chip)
   BYTE data;                 // Stores the data read from the LCD
   if(chip == GLCD_CS1)       // Choose which chip to read from
   return data;               // Return the read data
Most glcd.c driver code removed. Only changes left.
Reason: Forum rule #10
10. Don't post the CCS example code or drivers
- Forum Moderator
[/img]
char hello[]={"HELLO!"};
   glcd_init(ON);
   glcd_text57(0,0,hello,2,ON);
Markdem
PostPosted: Mon Oct 01, 2012 6:35 pm     Reply with quote
We need to see the rest of the code in main, but I bet this will have something to do with the oscillator set at a speed above 20Mhz or Proteus doing something stupid with timings.
Try to run the pic at 20Mhz or change the delays in glcd_writeByte to a higher number and see how you go.
Have Fun
vinay
rest of code !!!
PostPosted: Wed Oct 03, 2012 12:07 am     Reply with quote
#include <16F877A.h>
#device adc=10
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOPUT                    //No Power Up Timer
vinay
Solved it !!!!
PostPosted: Wed Oct 03, 2012 5:03 am     Reply with quote
Finally solved the prob Very Happy
there is read problem in glcd_readbyte(), the enable pin is not pulsed properly. I am attaching the code through which I got proper output
   //input_d();                 // Set port d to input
   set_tris_d(0xFF);
   output_high(GLCD_RW);      // Set for reading
   output_low(GLCD_E);
   delay_us(10);
   output_high(GLCD_E);       // Pulse the enable pin
   delay_us(10);
   output_low(GLCD_E);
   delay_us(10);
   data = input_d();          // Get the data from the display's output register
   output_low(GLCD_E);
Smile Smile Smile
MARKDEM, thank you for your reply.
Smile Smile Smile
