overmindx
bootloader problem if downloaded .hex has interrupt |
Posted: Tue Oct 02, 2012 7:26 am |
hi,
i have created a bootloader and it works fine if downloaded code doesnt have interrupt. however if it has an interrupt and it is triggered, the process suddenly becomes wierd. it resets for no reason. here is a sample code.
PCH v.4.124
main.c
#include <18F67K22.h>
#device PASS_STRINGS = IN_RAM
#FUSES NOWDT, INTRC_IO, NOPROTECT, NOIESO, BROWNOUT, PUT, NOCPD, STVREN, DEBUG, NOWRT, NOWRTD, NOEBTR, NOCPB, NOEBTRB, NOWRTC, NOWRTB, FCMEN, NOXINST, MCLR, RTCOSC_T1
#include "bootloader.h"
#use delay(clock=16000000)
#use rs232(baud=19200, xmit=PIN_G1, rcv=PIN_G2, stream=PC)
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7, stream=SERIAL_INT)
#define BUFFER_SIZE 255
#include <stdlib.h>
#include <string.h>
#include "interruptSerial.c"
#include "gsm.c"
int1 testGSM(void)
strcpy(DESIRED_RESPONSE, "OK");
clear_buffer();
delay_ms(200);
fprintf(SERIAL_INT, "AT\r");
if(GetResponse())
fprintf(PC,"active\n");
return TRUE;
return FALSE;
void main(){
delay_ms(2000);
enable_interrupts(INT_RDA);
do{
testGSM();
}while(1);
#int_rda
void rda_isr(void)
INTSERIAL_FLAG = 1;
RXD_DATA[WRITE_CNTR++]=fgetc(SERIAL_INT);
bootloader.h
#define LOADER_END 0x6FF
#define LOADER_SIZE 0x5FF
#define USE_STATEMENT_SIZE 0x100
#ifndef _bootloader
#build(reset=LOADER_END+1+USE_STATEMENT_SIZE, interrupt=LOADER_END+9+USE_STATEMENT_SIZE)
#org 0, LOADER_END+USE_STATEMENT_SIZE {}
on a side note:
if i remove the bootloader.h and run the code directly without using the bootloader, everything works great but if i place the bootloader.h, it resets if the interrupt is triggered.
please help. thanks |
Posted: Tue Oct 02, 2012 7:31 am |
The actual _bootloader_, needs to have the extra code present to re-vector the interrupt.
That is the section starting #int_global, in ex_bootloader.c, and also why the 'main' is located at address 0x20/0x40 (to leave space for this).
overmindx
Posted: Tue Oct 02, 2012 7:47 am |
hi,
thanks for the swift reply..
my bootloader gets the code from a flash memory chip via SPI. this works great for code without interrupts.
here is part of my bootloader code
#device adc=12
#use rs232(force_sw,baud=19200, xmit=PIN_G1, rcv=PIN_G2, stream=PC)
#define _bootloader
#include <spi_lib.c>
#include "loader.c"
#if defined(__PCM__)
#org LOADER_END+1+USE_STATEMENT_SIZE,LOADER_END+10+USE_STATEMENT_SIZE
#elif defined(__PCH__)
#org LOADER_END+2+USE_STATEMENT_SIZE,LOADER_END+20+USE_STATEMENT_SIZE
void application(void) {
while(TRUE);
#if defined(__PCH__)
#org 0x40,0xFF
#else
#org 0x20,0x3F
void main(void) {
if(input(PIN_B0))
setup_spi(SPI_MASTER|SPI_L_TO_H | SPI_XMIT_L_TO_H | SPI_CLK_DIV_64);
DTFOpen();
SetSizeFT();
load_program();
application();
#ORG default
#int_global
void isr(void) {
jump_to_isr(LOADER_END+5*(getenv("BITS_PER_INSTRUCTION")/8));
is something wrong with my code?
please help.. |
Posted: Tue Oct 02, 2012 8:08 am |
OK.
The vector used by the interrupt re-mapper, needs to be the same as the one used in the build statement. '9' is not going to be '5*bits per instruction'.....
overmindx
Posted: Tue Oct 02, 2012 8:28 am |
hi Ttelmah,
ok, i will try what you suggest tomorrow. since i dont have my board with me right now. thank you so much and will keep you posted as soon as i test it.
overmindx |
overmindx
Posted: Thu Oct 04, 2012 8:28 am |
hi Ttelmah,
it works! thanks for your help..
overmindx |
