losing my mind? or can I not figure out a simple for() loop?
Goto page 1, 2  Next
thefloyd
PostPosted: Mon Sep 17, 2012 10:30 am     Reply with quote
ok, so I'm not the best programmer/hardware guy out there but I can certainly handle a for() loop.. why oh why doesn't this work?
    for(bit=23;bit>=0;bit--) {
      if(bit_test(this_led, bit) == 1) {
        spi_write(ws2811_one);
      else {
        spi_write(ws2811_zero);
Whereas this works just fine:
    if(bit_test(this_led, 23) == 1) {
    else {
    if(bit_test(this_led, 22) == 1) {
    else {
    if(bit_test(this_led, 21) == 1) {
    else {
    if(bit_test(this_led, 20) == 1) {
..... all the way down to zero
Obviously the hardware is fine as the latter works.
I've tried all sorts of permutations of my for() loop. I'm sure I'm missing something obvious.. can someone provide me with the electronic slap upside the head?
PostPosted: Mon Sep 17, 2012 11:50 am     Reply with quote
Make the first code into a small but compilable test program, with the
#include for the PIC, #fuses, #use delay(), main(), all variable and
constant declarations, etc.
Also post your compiler version.
Number types...
If you have an unsigned integer, it is _always_ going to be >=0.
When you decrement past 0 it wraps to be 255,
Hence loop can't work.
thefloyd
PostPosted: Mon Sep 17, 2012 12:16 pm     Reply with quote
Thanks for the quick replies.
ttelmah, nice catch. This explains a different problem I had somewhere else, but not this one as the following don't work:
for(bit=23;bit!=255;bit--)
or
int bit;
PCM: my compiler version is 4.134
A quick sample program is below. I've included the broken send_frame() routine as the working one is fairly obvious.
#include <18f46k22.h>
#Fuses INTRC_IO,PLLEN,PRIMARY_ON,NOFCMEN,NOIESO,PUT,
#Fuses BROWNOUT,BORV29,NOWDT,
#Fuses CCP2C1,NOPBADEN,CCP3B5,
#Fuses NOHFOFST,TIMER3B5,NOMCLR,
#Fuses NOSTVREN,NOLVP,NOXINST,NODEBUG
#Fuses NOPROTECT,NOCPB,NOCPD,NOWRT,NOWRTC
#Fuses NOWRTB,NOWRTD,NOEBTR,NOEBTRB
#use delay( clock=64000000,INTERNAL )
#define LED_STRIP_LEN 50
unsigned int32 led_strip_colors[LED_STRIP_LEN];
#define ws2811_zero 0b10000000
#define ws2811_one 0b11110000
void send_frame() {
  unsigned int16 i;
  unsigned int bit;
  unsigned int32 this_led;
  for(i=0;i<LED_STRIP_LEN;i++) {
    this_led = led_strip_colors[i];
    for(bit=23;bit!=255;bit--) {
      else {
  delay_us(50); // latch
void single_color(unsigned int32 color1) {
  unsigned long i;
  for(i=0; i<LED_STRIP_LEN; i++) {
    led_strip_colors[i] = color1;
void main(void) {
  unsigned int16 i;
  unsigned int j;
  setup_spi( SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_16 );
  delay_ms(250);
  single_color(0xFFFFFF);
  send_frame();
  delay_ms(5000);
  single_color(0xFFC58F);
  send_frame();
  delay_ms(5000);
  single_color(0xFF9329);
  send_frame();
  delay_ms(5000);
  single_color(0xFF0000);
  send_frame();
  single_color(0x00FF00);
  send_frame();
  single_color(0x0000FF);
  send_frame();
  sleep;
PostPosted: Mon Sep 17, 2012 12:54 pm     Reply with quote
You may be able to debug your problem by running your program in
MPLAB simulator. Modify it as shown below in the lines marked "TESTING"
and setup the UART1 feature of MPLAB to display hardware UART text in
the Output Window of MPLAB. This post explains how to do that:
http://www.ccsinfo.com/forum/viewtopic.php?t=23408&start=1
For example, if your send_frame() routine gets an input value that is all
1's, then it should transmit 24 bits of all 1's, like this:
111111111111111111111111
With this method you can test the "pure code" portion of your program
to see if it's working OK. It doesn't test SPI. It just tests your internal
algorithm. But at least you can easily test it now.
Note all lines marked with *** TESTING ***:
#use rs232(baud=9600, UART1, ERRORS)  // *** TESTING ***
#define LED_STRIP_LEN 1   // *** FOR TESTING ***  set to 1 (was 50)
void send_frame() {
  unsigned int16 i;
  unsigned int bit;
    for(bit=23; bit!=255; bit--) {
       // spi_write(ws2811_one);
        putc('1');  // *** TESTING ***
      else {
        //spi_write(ws2811_zero);
       putc('0');   // *** TESTING ***
 putc('\r');  // *** FOR TESTING ***
  unsigned long i;
void main(void) {
  unsigned int16 i;
  unsigned int j;
  // Commented out the next two lines *** FOR TESTING ***
  //setup_spi( SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_16 );
  //delay_ms(250);
  send_frame();
  while(1);  // *** TESTING ***
  delay_ms(5000);
  send_frame();
  delay_ms(5000);
  send_frame();
  delay_ms(5000);
  send_frame();
  send_frame();
  send_frame();
//  sleep;
thefloyd
PostPosted: Mon Sep 17, 2012 3:33 pm     Reply with quote
Sometimes it takes someone else to remind you what you already know :D I've used putc/printf/etc to debug programs that deal with text. Silly me not to think of it in this case. I put a USB to rs232 converter on my breadboard and found some interesting things.
1) my loop seems to work fine. Tested it with several combinations of data and saw exactly what I expected. the bit!=255 part seems to stop the loop right where it should. I got 1s and 0s exactly where I was expecting them and exactly as many of them as I was expecting.
2) There's something wrong with my hardware or setup (or compiler?), and the loop timing may be throwing timing off enough to break things, see below.
3) My PIC can't be oscillating at 64mhz. Despite the use of:
and
The RS232 data was useless. Off to debugging land I went, I tried changing the use delay line to "clock=8000000, INTERNAL" and viola! My RS232 data made sense.. Note I had forgotten to change the fuse back to NOPLLEN yet this worked. huh?
So now the next question is why the hell isn't my PIC running at 64mhz? I have #Fuses PLLEN and a proper #use delay setting. Is this the bug I'm really chasing?
Am I missing something in the setup?
PostPosted: Mon Sep 17, 2012 3:55 pm     Reply with quote
This program blinks an LED at a 1 Hz rate with vs. 4.134. I tested it in
hardware with an 18F45K22, but it should also work with an 18F46K22.
#include <18F45K22.h>
#fuses INTRC_IO,NOWDT,PUT,BROWNOUT,NOLVP
#use delay(clock=64M)
// Blink the LED once per second.  The 10/90 duty cycle
// makes it easier to time the flashes with a stopwatch.
   output_high(PIN_B0);
   output_low(PIN_B0);
   delay_ms(900);
thefloyd
PostPosted: Sat Sep 29, 2012 2:50 pm     Reply with quote
So after taking a break, head scratching, debugging, and taking another break I got to take a better look on a scope.
For some reason, it seems trying to execute the for() loop is severely retarding the timing. Enough that there's at least a 50us delay, and that's causing the light string to latch and move on with life. I really didn't think that'd be possible (at 64 mhz!), but I can definitely confirm the data is coming much more slowly with long(ish) pauses when the loop is executed versus doing the bit test sequentially and banging the bits out.
Am I being unrealistic with my timing demands here? Or is there something else I'm missing? Or is there something else possibly going on? I know there are people doing this on a 16mhz arduino (with some careful optimization, I get that.. but 64mhz should allow me to be a bit more "lazy" no?)
PostPosted: Sat Sep 29, 2012 3:13 pm     Reply with quote
Yes there is, and you put it in there. See the line in bold in your code below:
void send_frame() {
unsigned int16 i;
unsigned int bit;
else {
PostPosted: Sat Sep 29, 2012 3:46 pm     Reply with quote
style: bit_test is True or false Boolean purity ;-))
// VS
if(bit_test(this_led, bit))
can't help but notice that
thefloyd
PostPosted: Sun Sep 30, 2012 9:47 am     Reply with quote
void send_frame() {
unsigned int16 i;
unsigned int bit;
      else {
Yes. The latch is there but ONLY after iterating through the loop. What I'm saying is that WITHIN the loop, I'm finding at least a 50us delay.
this works:
void send_frame() {
  unsigned int16 i;
    else {
    else {
    if(bit_test(this_led, 1) == 1) {
    else {
    if(bit_test(this_led, 0) == 1) {
    else {
  delay_us(50);
THIS doesn't:
void send_frame() {
  unsigned int16 i;
  unsigned int bit;
      else {
  delay_us(50);
I'm seeing delays of > 50us INSIDE the for(bit=23;bit!=255;bit--) loop. Debugging prints the right number of 1s and 0s to the screen. But when executed on the actual hardware, only the first LED does things (flickers, does weird stuff). Probing with a scope and the timing inside the loop is all broken, but doing each of the 24 bit tests by hand manages to avoid the 50us+ pauses. Why?
PostPosted: Sun Sep 30, 2012 10:27 am     Reply with quote
You don't show your SPI configuration code.
I'd say it is using soft SPI at perhaps about 200KHz.
This will then take 48uSec to send the bytes.
thefloyd
PostPosted: Sun Sep 30, 2012 10:47 am     Reply with quote
Sorry, the setup_spi command is earlier up in the thread. This is a PIC @ 64mhz with the following:
PostPosted: Sun Sep 30, 2012 11:20 am     Reply with quote
However it'd be a _lot_ faster, to generate your own bit mask, load this with 2^23, and just rotate this once each time round the loop, and 'and' this with the value.
Problem is that 'bit test' with a constant generates a single machine instruction. With a variable, it generates a '1', then rotates this by the specified number, and 'and's this to find if the bit is true/false.
So your test generates an average of 13 4byte rotations each time round the loop. Add the loop count and the and operation, and you have something like perhaps 200 instructions, so I can see it taking perhaps 15+uSec.
Using your own mask instead, which only has to rotate once each time round the loop will save a lot of time.
PostPosted: Sun Sep 30, 2012 12:09 pm     Reply with quote
As a comment, the fastest way to do this is probably:
     for (bit=0;bit<24 bit++) {
          else {
     this_ked*=2;
This way you test the single _fixed_ bit (fast) and just rotate your stored number once each loop. I'd guess at least a dozen times faster.
Goto page 1, 2  Next
Page 1 of 2
