John Guest
Newbie timer problem... |
Posted: Tue Dec 03, 2002 12:59 pm |
Hello experts!
I'm trying to get a 16F84 to count external pulses but it doesn't work even though it compiles ok with my PCM 2.686.
The idea was to start the timer, set it to 0 and wait for some ms as is counts and get the readout to a LCD. Then resetting it again and so on. The LCD routine is ok but I the timer doesn't seem to react?
I've connected the pulse source to Rb0 and set it as:
set_tris_b ( 0xF9 ); // 0b11111001
The main code looks something like this:
void main( void )
int count;
setup_counters(RTCC_EXT_L_TO_H, WDT_2304MS);
enable_interrupts(INT_EXT);
set_rtcc(0);
count=get_rtcc();
printf(LCD_PutChar,"\%3U",count);
What am I doing wrong? I've looked for answers everywhere but to no avail. I don't use an ISR, is that necessary?
Thanks in advance!
/John
___________________________
Original Post ID: 9734 |
Re: Newbie timer problem... |
Posted: Tue Dec 03, 2002 2:24 pm |
:=Hello experts!
:=I'm trying to get a 16F84 to count external pulses but it doesn't work even though it compiles ok with my PCM 2.686.
:=The idea was to start the timer, set it to 0 and wait for some ms as is counts and get the readout to a LCD. Then resetting it again and so on. The LCD routine is ok but I the timer doesn't seem to react?
For an example of how to use the RTCC, see the CCS example
file, "EX_PULSE.C". This is in your C:\PICC\Examples folder.
Here is an example of how to use INT_EXT to count inputs on RB0.
<a href="http://www.pic-c.com/forum/general/posts/2138.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/2138.html</a>
Original Post ID: 9740 |
John Guest
Posted: Wed Dec 04, 2002 3:22 pm |
:=:=Hello experts!
:=:=I'm trying to get a 16F84 to count external pulses but it doesn't work even though it compiles ok with my PCM 2.686.
:=:=The idea was to start the timer, set it to 0 and wait for some ms as is counts and get the readout to a LCD. Then resetting it again and so on. The LCD routine is ok but I the timer doesn't seem to react?
:=For an example of how to use the RTCC, see the CCS example
:=file, "EX_PULSE.C". This is in your C:\PICC\Examples folder.
:=Here is an example of how to use INT_EXT to count inputs on RB0.
:= <a href="http://www.pic-c.com/forum/general/posts/2138.html" TARGET="_blank"> <a href="http://www.pic-c.com/forum/general/posts/2138.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/2138.html</a></a>
Thanks for the links even though I was hoping for a more "direct answer" of what I did wrong ;-) But finally I got it up and running!
Thanks again,
/John
Original Post ID: 9780 |
