RS232 problem
jameszum
RS232 problem
PostPosted: Wed Sep 19, 2012 3:25 pm     Reply with quote
I am using 2 16F877A one each on a separate board, and i am using soft rs232 communication to pass information between the boards. The "Generator" boards sends a single byte in this case a 0x52 (R) to the "Controller" board, and the "Controller" board responds with a 0x58 (X).
I have No problem sending the byte from the "Generator" boards to the "Controller" Board but when the "Controller" board sends it a response the generator board receives garbage.
By garbage I mean the following
the generator board sends
sending 52
"hex data"
7365 6E64 696E 6720 3532 0A
and the generator receives the following
"return information"
return 00 NOTE some times there are 3 characters here
"hex data"
7265 7475 726E 2030 300A
"last printed data"
got a 00
"hex Data"
676F 7420 6120 3030 0A
Just monitoring the Receive line for unit 1
I get what is expected
X
"hex Data"
58
The problem seems to be with the receiver on the Generator board
note the stream= test is for communicating with a monitor program
and when removed the problem still remains.
I have gone through the forum but have not found any help with this problem.
// Generator
#include <16F877A.h>
#fuses NOWDT
#fuses HS
#fuses NOPUT
#fuses NOPROTECT
#fuses NOBROWNOUT
#fuses NOLVP
#fuses NOCPD
#fuses NOWRT
#use delay(clock = 10000000)
#use standard_io(all)
//#define rs232 out         PIN_B0 // rs232 out
//#define rs232 in          PIN_B1 // rs232 in
#define verify_sw           PIN_B3 // input
#define LDP                 PIN_B4 // output
#define RDP                 PIN_B5 // output
#define RESET_in            PIN_C5 // input
// when receiving wait 10 MS if no data them an error
#use rs232(baud=9600,FORCE_SW, ERRORS, XMIT = pin_C0, rcv = pin_C3,stream = test)
#use rs232(baud=9600,FORCE_SW, ERRORS, XMIT = pin_B0, rcv = pin_B1,stream = Cont)
int I1,J1,J2,J3;
void SSend_Data(char data); // write a byte of data
char SRead_Data(void); // read a byte of data
void S_RESET(void);   // tell all ro erase there stored data
//****************** start of main *******************************************
    PORT_B_PULLUPS(true) ;// set app pullups on b high
    output_low(LDP);
    output_low(RDP);
    while(1) // Loop Here for ever
     if (input(RESET_in) == 0)// check the switch
            while (!input(RESET_in)); // wait until a one
            S_RESET(); //
     delay_ms(10);
   }//end of while(1)
}//end of main()
void S_RESET()
    SSend_data(0x52); // send the "R" command
     I1 = SRead_Data();// should be an X
     fprintf(test,"got a %x\n",I1);
 // clear the EEPROM in the chip
void SSend_data(char data) // write a byte of data
        fputc(data,Cont); // send over rs232
        fprintf(test,"sending %x\n",data); // send over rs232
// kbit has gone low  we have seen the start bit
    while (!kbhit())//wait for a return
    J1 = fgetc(Cont);// get a byte of data
    fprintf(test,"return %x\n" J1,);
    return J1;
// Controller
#fuses NOWDT
#fuses HS
#fuses NOPUT
#fuses NOPROTECT
#fuses NOBROWNOUT
#fuses NOLVP
#fuses NOCPD
#fuses NOWRT
//#define rs232 in          PIN_B0 // rs232 in
//#define rs232 out         PIN_B1 // rs232 out
#use rs232(baud=9600,FORCE_SW ,XMIT = pin_B1,rcv = pin_B0,stream = main)
int input_data;
int SRead_Data(); // read a byte of data
void S_RESET(void);   // tell all to erase the EEPROM Memory
    output_low(LDP );
    output_low(RDP);
        input_data = SRead_Data();
        if (input_data == 0x52) S_RESET();// no return
        delay_us(10);
   }//end of while(1)
}//end of main()
//  end of MAIN Program
void S_RESET(void)
// on we saw the 0x52 so lets send the conformation
    SSend_data(0x58);// send the X for ok
    delay_ms(1);
}// end if S_RESET
    putc(data);
    delay_ms(5);
int SRead_data()// read a byte of data
        int  result;
        while (!kbhit());// wait for a bit
        result = getc();
        return result;
asmboy
PostPosted: Wed Sep 19, 2012 7:25 pm     Reply with quote
two softies eh ??
but in
s_readdata ....
you call kbhit () without a stream argument .
so i have to ask"
which stream does kbhit() look for received data in ???
your .LST file may answer that
i must say respectfully that two soft streams of RS232 in ONE pic is
actually TWO streams more than i would ever use, unless i was eager to sort out the exact kind of trouble you find yourself in.
have you noticed what the 18F46K22 can do for you ??
even at Q=1, they actually cost LESS than the PIC you started with and do so much more, AND with TWO nice hardware uarts ??
( the ONLY kind that is worth using IMHO)[/code]
PostPosted: Thu Sep 20, 2012 12:10 am     Reply with quote
I totally agree with asmboy. Because of all the limitations a software UART is a last resort solution and you should be well aware of it's limitations. And then, there is a hardware UART in your chip and you don't even use it? Well, you created your own problem. Fix your hardware design.
Then there is this part of code in the Generator:
There is no ';' at the end of the while line, so for easier reading you have to format it like:
And then I have no clue as to what you are trying to do here. As long as there is no kbhit, you are reading data? Makes no sense and I guess that just by coincidence it is doing what you meant it to do:
PostPosted: Thu Sep 20, 2012 5:07 am     Reply with quote
I have to 'second' what asmboy says....upgrade to the 18f46k22s ! I now have a drawer full of 877s and 4550s collecting dust, the newer PIC is the way to go. Having 2 hardare UARTS is a treat getting rid of a lot of timing 'issues', code is smaller, tighter and WORKS. I dumped the 4550s since I get a USB-TTL module for $4(qty 1), again gets rid of a LOT of 'issues'.
SOME newer technology is great, this from a guy with 20 year old 877s.
hth
jay
jameszum
PostPosted: Thu Sep 20, 2012 10:31 am     Reply with quote
Good Morning
First, new processor for this project is not going to happen.
Project was given to me on Sept 4 and has to be completed by Sept 27.
The project has 8 boards and I had the micros so I went with them.
However I will keep it in mind for future projects.
Second the missing semicolons,
the code was copied from a larger procedure and it got dropped, sorry about that.
    while (!kbhit())//wait for a return  missing semi here
    return J1;
Third the soft RS232 I found that putting a delay_ms(20) after each transmit on both units solved the problem.
 //#use rs232(baud=9600,FORCE_SW, ERRORS, XMIT = PIN_B1, RCV = PIN_B0,stream = Cont)
        delay_ms(20);
        disable_interrupts(INT_TIMER0);
        fprintf(test,"sending %x \n",data); // send over rs232
//        delay_ms(20);
