Problem with simple code
Goto page Previous  1, 2
Re: Problem with simple code
PostPosted: Mon Sep 17, 2012 4:34 pm     Reply with quote
andys wrote:
I just realize that i can compile pic18f4550 but i can compile the series dspic30,....
WTF?
Did you change something or is this just magic that he PIC18 now compiles?
Some feedback would be nice.
I can't understand because the pch compiler is exist
Sigh... Did you do ANY research?
When I go to the CCS homepage and check the page for supported devices, it is easy to find. Quicker than it took you to type the question. Have a look at http://www.ccsinfo.com/devices.php?page=devices
No, PCH does NOT support the dsPIC/PIC24 devices. For those you need PCD or PCWHD.
And... CCS v4.057 is old, very old. It is one of those early prototype versions of the V4 compiler and should never be used because it is full of bugs. I know, it is one of the versions available for download through one of the illegal methods. But at least safe everyone a lot of time by using a stable version. V4.070 or newer.
Page 2 of 2
