Help for Timer0 interrupt
Spradecom
PostPosted: Thu Sep 13, 2012 3:29 am     Reply with quote
I want to control AC phase angle controlling TRIAC gate signal. I am using timer0 interrupt with
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_4);
and check adc value from trimpot.
I am using 16F684 with 4MHz internal oscillator,
I had read ADC in and drive MOC3001 using PWM.
ADC value converted from(0-1023) to (0-10) using conversion. As 0-10ms conversion, but I found flickerring at PWM output in oscilloscope & on Load lamp. Either problem from Timer0. Can anyone give any solution to resolve this problem ?
I had checked individually ADC & PWM output without detecting zero-cross detect of AC using optocoupler (EL817D).
& using software delay routine & PWM with zero-cross detect it worked properly. But using zerocross detect, with ADC & PWM, I'm stuck on this problem.
Mike Walne
PostPosted: Thu Sep 13, 2012 9:39 am     Reply with quote
I'm not sure about what you're saying does/doesn't work.
I need a lot more clear, concise detail about what you are actually doing in both hardware and software. You're the one with the board in front of you, we're all having to second guess.
Mike
PostPosted: Thu Sep 13, 2012 4:27 pm     Reply with quote
got a SCHEMATIC??
and your FULL CODE ??
a faulty zero cross detector can make your whole thing bad -
but ???
How do you SYNC to line rate zero-cross -
?? PWM alone is going to random trigger w/0
sync and isn't going to mean much !!
SO how do you know its the timer and not your program logic??
etc etc etc
better still -how can WE tell w/o any schematic or full code to review??
Spradecom
PostPosted: Fri Sep 14, 2012 1:42 am     Reply with quote
asmboy wrote:
got a SCHEMATIC??
but ???
etc etc etc
My modified code is
unsigned int8 temp_port_a;
unsigned int8 buff[20]={};
void shift_buff(void);
void shift_adc_buff(void);
#int_TIMER0
void  TIMER0_isr(void)
   disable_interrupts(INT_TIMER0);               //disable timer0 interrupt
   TRAIC_GATE = 0;
//   delay_us(350);
//   TRAIC_GATE = 1;
#int_RA
void  RA_isr(void)
   TRAIC_GATE = 1;
   set_timer0(firing_angle);
   enable_interrupts(INT_TIMER0);               //Enable timer0 interrupt
   temp_port_a = PORTA;
      setup_adc_ports(sAN5|VSS_VDD);
      setup_adc(ADC_CLOCK_DIV_64);
      setup_timer_0(RTCC_INTERNAL|RTCC_DIV_128);
      setup_timer_1(T1_DISABLED);
      setup_vref(FALSE);
      enable_interrupts(INT_RA);
      setup_oscillator(OSC_8MHZ);
      initialize_ports();
      initialize_variables();
      STATUS_LED ^= 1;
      read_pot_position();
void initialize_ports(void)
   output_float(PIN_A0);
   output_float(PIN_A1);
   output_float(PIN_A2);
   output_float(PIN_A3);
   output_float(PIN_A4);
   output_float(PIN_A5);
   output_high(PIN_C0);
   output_float(PIN_C1);
   output_high(PIN_C2);
   output_float(PIN_C3);
   output_float(PIN_C4);
   output_float(PIN_C5);
void initialize_variables(void)
   unsigned int8 i;
   firing_angle = MINIMUM_FIRING_ENGLE;
   for(i=0;i<20;i++)
      buff[i]=firing_angle;
void read_pot_position(void)
   unsigned int32 adc_output_data;
   unsigned int16 i;
   unsigned int8 temp_data;
   unsigned int8 fire_data;
   unsigned int16 read_data;
   set_adc_channel(5);
   adc_output_data = 0;
   for(i = 0; i <100; i++)
      adc_output_data += read_adc(ADC_START_AND_READ);
      read_data=(unsigned int16)(adc_output_data/i);
   temp_data = (unsigned int8)(read_data / 7.8);
   fire_data = MINIMUM_FIRING_ENGLE + temp_data;
   firing_angle =buff[0];
   shift_buff();
   buff[19]=fire_data;
   unsigned int8 j;
   for(j=0;j<19;j++)
       buff[j]=buff[j+1];
& Configuration as following
#include "16F684.h"
#device adc=10
//                     Defining All FUSES
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES PROTECT                //Code not protected from reading
#FUSES CPD                       //No EE protection
#FUSES PUT                      //Power Up Timer
#use delay(clock=8000000)
//                     Defining All SFR's
#BYTE PORTA = 0x05
#BYTE PORTC = 0x07
//                     Defining All Ports
#BIT ICD_2_DATA         = PORTA.0               //INPUT
#BIT ICD_2_CLOCK       = PORTA.1               //INPUT
#BIT NC_1             = PORTA.2               //INPUT
#BIT ICD_2_RESET      = PORTA.3               //INPUT
#BIT ZERO_CROSSING       = PORTA.4               //OUTPUT
#BIT NC_2             = PORTA.5               //OUTPUT
#BIT STATUS_LED         = PORTC.0               //OUTPUT
#BIT ANALOG_INPUT      = PORTC.1               //OUTPUT
#BIT TRAIC_GATE         = PORTC.2               //OUTPUT
#BIT NC_3            = PORTC.3                //OUTPUT
#BIT NC_4            = PORTC.4                //INPUT
#BIT NC_5            = PORTC.5               //INPUT
//                     Defining All Data
#define MINIMUM_FIRING_ENGLE   115
#define MAXIMUM_FIRING_ENGLE   245
//                     Defining All Variables
unsigned int8 firing_angle;
//                     Defining All Functions
void initialize_ports(void);
void initialize_variables(void);
void read_pot_position(void);
Mike Walne
PostPosted: Fri Sep 14, 2012 2:35 am     Reply with quote
Still no schematic.
You're keeping us all in the dark.
Mike
