PIC10F20x
edi
PIC10F20x
PostPosted: Wed Sep 12, 2012 1:04 am     Reply with quote
I want to make a Blink a LED every 30 Sec.
Using 10F20x, 1 push-button and one LED.
The device should be in SLEEP mode till the push-button press as it act as On/Off switch, blink the LED and go to sleep for a 30 sec, then wake-up blink a LED and go to sleep again for 30 sec.
Only when pressing the push-button again it should go to sleep forever (till on/off again)
Can someone help me with this kind of code.
Thanks.
PostPosted: Thu Sep 13, 2012 1:00 pm     Reply with quote
1. Post the full part number of the PIC you are using (not 10F20x).
2. Try to write the code. Then post your program and explain what
works, and what doesn't work.
3. Post your CCS compiler version.
4. We don't want to do your school homework for you. You must do it.
We can help if you get stuck on a certain part of it.
