Easy pic board with ccs c compiler
hisham.i
PostPosted: Sun Sep 02, 2012 11:44 pm     Reply with quote
I want to ask if ccs creates development tool for wide range of micro controllers like easy pic board?
The second question is can i program the micro controller directly while it is attached on easy pic from ccs program, like if i am using mikro c program?
PostPosted: Mon Sep 03, 2012 1:32 pm     Reply with quote
1) Please check out their main website as it'll have the latest information...
The 'easy PIC boards tend to be a 'general purpose' tutorial tool and not really suited for small projects. More for school work or basic R&D.
2) Providing the board has an ICSP header and you have an ICSP compatible programmer (like the PICkit 3) ,you should be able to download your code into it.
hth
jay
PostPosted: Mon Sep 03, 2012 4:55 pm     Reply with quote
I want to ask if ccs creates development tool for wide range of micro controllers.
The forum is not the best place for this type of question.
Go look at the CCS page on their compilers:
http://www.ccsinfo.com/content.php?page=compilers
Click on the Device Support button to see a list of PICs that are supported.
hisham.i
PostPosted: Thu Sep 06, 2012 5:31 am     Reply with quote
Thank you for reply,
PCM programmer when you test your programs, do you a simulator like easy pic to test them or you have another way to test your programs?
Gabriel
PostPosted: Thu Sep 06, 2012 6:32 am     Reply with quote
Breadboard + PIC = best simulator ever!
g.
CCS PCM 5.078 & CCS PCH 5.093
dyeatman
PostPosted: Thu Sep 06, 2012 6:06 pm     Reply with quote
I use the Easy PIC 7 with the CCS ICD64 and it works great!
Google and Forum Search are some of your best tools!!!!
gpsmikey
PostPosted: Fri Sep 07, 2012 9:44 am     Reply with quote
Is this the EasyPIC 7 you are referring to ?
http://www.microchipdirect.com/productsearch.aspx?Keywords=TMIK013
One complaint I saw is that the LCD is connected to port D limiting the use with the smaller PICS although, as one person pointed out, nothing to stop you from using a smaller PIC and jumpering from the PORT D header to another port to drive the LCD. I recently purchased the ICD64 although have not had a chance to play with it yet - this looks like a good combo (I had been looking at the other dev board that Microchip sells that PCM Programmer seems to use for his testing).
mikey
mikey
dyeatman
PostPosted: Fri Sep 07, 2012 2:52 pm     Reply with quote
Yep, that's the one...
gpsmikey
PostPosted: Fri Sep 07, 2012 5:48 pm     Reply with quote
OK, thanks. Looks like a good combo - the best simulator out there is ... hardware !!
mikey
mikey
dyeatman
PostPosted: Sat Sep 08, 2012 6:32 am     Reply with quote
I actually have an EP6 and an EP7. I do a lot of prototyping and these have
really worked well for me. On the EP6 I use the ICD2 header with the
ICD64 On the EP7 I plug the ICD64 into the port provided on the board. I
have had a few occasions where the LCD/GLCD on the board interfered with
the ports so I also have external versions for when I need them on other ports.
