Power PWM module 18f2331
madcreator
PostPosted: Fri Sep 07, 2012 7:48 am     Reply with quote
Hi, I'm using the 18f2331 microcontroller from microchip and I want to use the Power Pwm module.
I need to control each PWM (PWM0,PWM1,PWM2,PWM3) independently to drive this :
How can I drive a pair to drive the bridge ??
Thanks for your help !
Gabriel
PostPosted: Fri Sep 07, 2012 9:36 am     Reply with quote
i dont think anyone is going to give you the code for exactly what you want or code it for your.... you can try your luck searching on the code library.
try coding it yourself, and should you have any problems, then the forum users will gladly help you.
G.
CCS PCM 5.078 & CCS PCH 5.093
madcreator
PostPosted: Fri Sep 07, 2012 11:25 am     Reply with quote
I don't want the exact code, I just want someone that understand how the power pwm module work ! So I can understand it !
I have already tried coding but nothing works that why I'm posting here!
Madz Very Happy
PostPosted: Fri Sep 07, 2012 12:02 pm     Reply with quote
Then post the code that you tried but didn't work.
jeremiah
PostPosted: Fri Sep 07, 2012 12:04 pm     Reply with quote
Generally the first step (and part of our forum guidelines), is to create a small, compilable program that only addresses your issue, and post it up here so we can take a stab at why the code you tried doesn't work. We're not looking for your entire program, just something that compiles and runs on it's own and that illustrates the problem.
Once you can get that up, we can try to help you out better.
madcreator
PostPosted: Fri Sep 07, 2012 12:08 pm     Reply with quote
#define POWER_PWM_PERIOD 1999
setup_power_pwm_pins(PWM_BOTH_ON, PWM_BOTH_ON, PWM_OFF, PWM_OFF);
//Frequency = Fosc / (4 * (period+1) *postscale)
setup_power_pwm(PWM_FREE_RUN, 1, 0, POWER_PWM_PERIOD, 0, 1,0);
     SET_POWER_PWM0_DUTY(100);
     set_power_pwm_override(1,1,0);
     SET_POWER_PWM2_DUTY(30);
     set_power_pwm_override(2,1,0);
This code is to make the motor turn in one direction.
PostPosted: Fri Sep 07, 2012 1:39 pm     Reply with quote
Do you have to use an 18F2331 with a Power Control PWM module ?
Because your Tip#15 shows a PIC with an ECCP module. It's very
easy to configure Full Bridge mode with an ECCP with CCS. Example:
http://www.ccsinfo.com/forum/viewtopic.php?t=29565&start=1
madcreator
PostPosted: Fri Sep 07, 2012 1:45 pm     Reply with quote
Cool example ! I've made the circuit like that,and this pic is quite little tht why I choosed this one, and I was thinking that the power pwm module was easy to use...
I think I will make a another circuit with a 18f4550 and use the ECCP !
Thanks a lot for your help.
Madz
PostPosted: Fri Sep 07, 2012 1:59 pm     Reply with quote
Here are some PICs with an ECCP module:
18F1220/1330
18F4221/4321
18F4220/4320
18F4410/4510/4515/4610
18F4480/18F4580
18F4420/4520
18F4525/4620
18F4550/4455
There's a lot more. I just stopped at that point.
