how to avoid multiplication overflow ?
spilz
PostPosted: Fri Sep 07, 2012 3:07 am     Reply with quote
hello everybody
I need to know if there is a way to "avoid multiplication overflow"
I explain Smile :
actually I have :
int a=2,b=200,c;
c = a*b;
by this code, I obtain c = 144 , cf 0 <= c <= 255
but I would like to avoid overflow and obtain c = 255
How can I do that?
thanks for your help
Spilz
RF_Developer
PostPosted: Fri Sep 07, 2012 3:31 am     Reply with quote
There is no way to "avoid" the overflow; overflow behaviour is fixed in the harware; what you are wanting to do is deal with the overflow in a different way.
So you have to do it in 16 bit arithmetic and then limit/clamp the result to 8 bits:
// Don't forget ints in CCS C are 8 bit unsigned. The same method
// works for other sizes & signedness with suitable modifications.
int a=2,b=200,c;
int16 Temporary;
Temporary =  (int16) a * b;  // Only need to cast one of the operands. Casting both makes no difference; just takes longer to type!
if (Temporary > 255)
    c = 255;
    c = Temporary;    // Note this invloves an implied truncation of the result.
RF Developer
