Save data in program memory - Pic 24f
joseph20480
PostPosted: Thu Sep 06, 2012 1:26 pm     Reply with quote
I'm trying to save data in the space memory program of pic24f....but nothing.
1. Address for my data
#org 0x000200, 0x000201 {}
2. Write my data
int16 A;
   A = 100;
   write_program_memory(0x000200, &A, 2);
3. Read my data
int16 B;
    B=0;
    read_program_memory(0x000200,B,2);
>>> Why now 'A' is not equal 'B' ???
Thanks in advance is you have an idea, is you see a terrible error !
PostPosted: Thu Sep 06, 2012 1:47 pm     Reply with quote
Change to:
read_program_memory(0x000200,&B,2);
PostPosted: Thu Sep 06, 2012 1:53 pm     Reply with quote
Key thing to understand on all these PIC's, is that _erase_ has to be done on an entire page.
The write function will erase memory, if you write to the first location of a page, _but not otherwise_. Means unless the page has already been cleared, what you write will be corrupted by what is already there.
To write a small area of memory to the PIC, you have to read the entire page into RAM, modify the bytes you want to change, and write the whole page back.
This is a hardware limitation of the chips, and not a code problem.
Start by reserving an entire page, starting on a page boundary, and then things can start to work.
The page size depends on your PIC, but is typically 2KB on PIC24's.
joseph20480
PostPosted: Thu Sep 06, 2012 2:07 pm     Reply with quote
Thanks for your reply !
I do the correction....
Now i try to see the real value with this line :
printf("A: %lu   -  B: %lu\n\r",A,B);
result : "A : 100 - B : 65535"
jeremiah
PostPosted: Thu Sep 06, 2012 7:09 pm     Reply with quote
You must write program memory in 4 byte chunks and the 4th byte must be 0x00. It has to do with how instructions are stored in program memory, but it affects data too.
joseph20480
PostPosted: Fri Sep 07, 2012 6:56 am     Reply with quote
ok...
So i need to reserve more space ??
Anyone have a code ? and example ?
thanks in advance
