Rs232 Weird Loop Issue - Proteus Simulation (Solved)
rajeshkhan808
PostPosted: Mon Sep 03, 2012 1:01 am     Reply with quote
So I am using the following code and simulating in Proteus. I am using Pic16F877A
#include <16F877A.h>
#fuses HS,WDT,NOPROTECT,NOLVP
{      char answer;
       Printf("Hello NY\r\n");
       while(true)
           output_high(PIN_B1);
           delay_ms(2000);
           output_low(PIN_B1);
           delay_ms(2000);
Now the funny thing is I keep on getting
Hello NY
Hello NY
Hello NY
Hello NY
Hello NY
as if its in a loop although its not ? Why is that. Why does the virtual terminal keep printing Hello NY continuously ? Any suggestion and remedies ?
PostPosted: Mon Sep 03, 2012 1:24 am     Reply with quote
Watchdog....
It is triggering, and restarting the code.
rajeshkhan808
PostPosted: Mon Sep 03, 2012 1:41 am     Reply with quote
Thanks that solved it
