Watch Dog Timer - delay (setup_wdt) and divisors (Solved)
rajeshkhan808
PostPosted: Sat Sep 01, 2012 2:01 am     Reply with quote
While going through the code of watch dog timer , I wanted to increase the timeout delay.I am using PIC16F877A.
The code example of CCS uses
setup_wdt(WDT_2304MS)
However the reference of setup_wdt states
For PCB/PCM parts:
 WDT_18MS, WDT_36MS, WDT_72MS, WDT_144MS,WDT_288MS, WDT_576MS, WDT_1152MS, WDT_2304MS
For PICĀ®18 parts:
WDT_ON,  WDT_OFF
For PICĀ®16 parts with software controlled WDT enabled:
WDT_ON, WDT_OFF, WDT_TIMES_32, WDT_TIMES_64, WDT_TIMES_128, WDT_TIMES_256, WDT_TIMES_512, WDT_TIMES_1024, WDT_TIMES_2048, WDT_TIMES_4096, WDT_TIMES_8192, WDT_TIMES_16384, WDT_TIMES_32768, WDT_TIMES_65536
How can I raise the timeout setting to 4 seconds ? also could anyone explain how the concept of divisors are working here ?
PostPosted: Sat Sep 01, 2012 3:20 am     Reply with quote
You can't.
The basic period of the watchdog on your chip is a nominal 18mSec. However you need to understand first, just how 'nominal' this is. Data sheet table 17-5. Max=33mSec, min=7mSec. So the '18', can vary by nearly 5:1....
Then this has eight selectable divisors, of 1,2,4,8,16,32,64 & 128.
Now look at the times offered by the fuses. What is 18*128?. 2304mSec. The eight options you have, correspond to the eight possible divisors. So 2304mSec (896mSec to 4224mSec), is the maximum time available. Now on some chips with some supplies, this will get to 4sec (4224mSec), but on others, it'll be under 1 second....
You can make an effective watchdog at _any_ interval you want, by using a 'tick' interrupt. So something like:
int8 watchdog;
#define 4SECONDS (200)
#int_timer2
void tick(void) {
    //run this at (say) 50* per second
    if (watchdog) {
       restart_wdt();
       --watchdog;
If you then set the watchdog up to use WDT_72MS, and instead of using restart_wdt in your code, use "watchdog=4SECONDS", then the counter will timeout, just over four seconds, and the watchdog will trigger between 52, and 132mSec latter.
Now I selected WDT_72MS, since this is the fastest watchdog setting _guaranteed_ to not timeout in less than the 20mSec between interrupts (worst case 28mSec for it's timeout). Obviously you'd need to adjust this to suit whatever 'tick' frequency you select.
If (for example), you wanted to sleep, and use the watchdog to wake, and give a 4 second time, then you'd need to simply sleep twice, so 2304mSec, becomes 4608mSec. However with the massive tolerance of the wachdog, with some systems you will get under 2 seconds, while with others over 8 seconds....
Mike Walne
PostPosted: Sat Sep 01, 2012 3:29 am     Reply with quote
It's all in the microchip data sheet.
The watch dog timer (WDT) has a nominal 18ms period.
The WDT prescaler is shared with Timer0 on the PIC16F877A
When assigned to the WDT, the nominal WDT period increases in factor of 2 steps from 18ms to 2304ms.
These periods correspond with the CCS setup values.
Mike
Douglas Kennedy
PostPosted: Sat Sep 01, 2012 3:55 pm     Reply with quote
Posting questions here might seem like a short cut to the poster in that the poster doesn't have to do much ...like read a datasheet , learn C or look up CCS special functions.
Some will choose to spoon feed these questioners others may not but the risk is the board becomes so pedestrian that the experts who have learned to drive will just pass by this board without stopping to answer questions.
Since beginner questions have a high probability of having been asked and answered it is the responsibility of the newcomer to search for these answers. The search button isn't broken.
bkamen
PostPosted: Sat Sep 01, 2012 5:09 pm     Reply with quote
Yep - I would have to admit to suffering from that.
I see so many posts that are so simple to find in the datasheet that they detract from my desire to visit the forum just to see similar questions clogging/obscuring the more interesting ones.
