Pichuqy_1
PIC24FJ64GA006 + keyboard 4x4 doesn't work |
Posted: Mon Aug 27, 2012 7:06 am |
Hi. I have a problem using the PIC24. when I compile the code using the library flex_kbd.c, there are many errors. I don't know why, I can't find the mistake. If I try the same code, using other microcontroller like PIC18F4550, it's works perfectly. Will it be a compiler mistake? Can someone help me??
#include <24FJ64GA006.h>
#device adc=10
#FUSES NOJTAG //JTAG disabled
#FUSES ICSP2 //ICD uses PGC2/PGD2 pins
#FUSES WINDIS //Watch Dog Timer in non-Window mode
#FUSES WPRES128 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16 //Watch Dog Timer PostScalar 1:32768
#FUSES HS
#FUSES NOCKSFSM
#FUSES NOOSCIO //OSC2 is clock output
#FUSES PR //Pimary oscillaotr disabled
#define _HDM64GS12
#define GLCD_CS1 PIN_E2
#define GLCD_CS2 PIN_E7
#define GLCD_DI PIN_E3
#define GLCD_RW PIN_E4
#define GLCD_E PIN_E5
#define GLCD_RST PIN_E6
//#define _ds1307
//#define RTC_SDA PIN_F0
//#define RTC_SCL PIN_F1
//#define _flex_kbd_4x4
//#define col0 PIN_E0
//#define col1 PIN_E1
//#define col2 PIN_E2
//#define col3 PIN_E3
//#define row0 PIN_E4
//#define row1 PIN_E5
//#define row2 PIN_E6
//#define row3 PIN_E7
//#define _mcp41010
//#define CS PIN_B7
//#define SCLK PIN_B5
//#define SI PIN_B6
#include <HDM64GS12.c>
#include <graphics.c>
#include <flex_kbd.c>
#include <clabe_acceso_lcd_grafico.c>
//#include <mcp41010.c>
#include <ds1307.c>
#include <ds1307_configuracion_lcd_grafico.c>
char valor_date[10];
char valor_lm35[5];
long medicion;
// setup_adc_ports (sAN9);
setup_adc (ADC_CLOCK_INTERNAL);
set_adc_channel(0);
delay_us(10);
//SET_PULLUP(PIN_B0);
// #rom int8 0xF00004={'1','2','3','4'};
retardo=250;
//glcd_init(ON);
kbd_init();
//enable_interrupts(int_ext);
//ext_int_edge(L_TO_H);
//enable_interrupts(GLOBAL);
//set_pot (150);
output_high(PIN_B0);
//INICIO_CLABE_ACCESO();
do
output_low(PIN_B0);
delay_ms(250);
}while(TRUE);
//// Flex_KBD.C ////
//// Generic keypad scan driver ////
//// kbd_init() Must be called before any other function. ////
//// c = kbd_getc(c) Will return a key value if pressed or /0 if not ////
//// This function should be called frequently so as ////
//// not to miss a key press. ////
//Keypad connection:
#ifndef _FLEX_KBD //directivas del pre-procesador
#define col0 PIN_E1
#define col1 PIN_A5
#define col2 PIN_C0
#define row0 PIN_E0
#define row1 PIN_C2
#define row2 PIN_C1
#define row3 PIN_E2
#endif //directivas del pre-procesador
// Keypad layout:
char const KEYS[4][3] = {{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}};
#define KBD_DEBOUNCE_FACTOR 33 // Set this number to apx n/333 where
// n is the number of times you expect
// to call kbd_getc each second
void kbd_init() {
short int ALL_ROWS (void)
if (input (row0) & input (row1) & input (row2) & input (row3))
return (0);
return (1);
char kbd_getc( ) {
static byte kbd_call_count;
static short int kbd_down;
static char last_key;
static byte col;
byte kchar;
byte row;
kchar='\0';
if(++kbd_call_count>KBD_DEBOUNCE_FACTOR) {
switch (col) {
case 0 : output_low(col0);
output_high(col1);
output_high(col2);
case 1 : output_high(col0);
output_low(col1);
output_high(col2);
case 2 : output_high(col0);
output_high(col1);
output_low(col2);
if(kbd_down) {
if(!ALL_ROWS()) {
kbd_down=false;
kchar=last_key;
last_key='\0';
} else {
if(ALL_ROWS()) {
if(!input (row0))
row=0;
else if(!input (row1))
row=1;
else if(!input (row2))
row=2;
else if(!input (row3))
row=3;
last_key =KEYS[row][col];
kbd_down = true;
} else {
++col;
if(col==3)
col=0;
kbd_call_count=0;
return(kchar);
Executing: "C:\Program files\Picc\CCSC.exe" +FD "Principal2.c" I+="C:\Program Files\PICC\Drivers;C:\Program Files\PICC\Devices;D:\PICS\Familias\Librerias_ccs_c(respaldar)" +DF +LN +T +A +M +Z +Y=9 +EA
>>> Warning 206 "C:\Program Files\PICC\Drivers\graphics.c" Line 531(1,1): Variable of this data type is never greater than this constant
*** Error 28 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 43(11,14): Expecting an identifier
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 43(20,21): Expecting a declaration
*** Error 81 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 44(1,2): Expecting a basic type
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 45(4,6): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 45(7,8): Expecting a declaration
*** Error 28 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 45(19,20): Expecting an identifier
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 45(21,22): Expecting a declaration
*** Error 29 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 45(38,39): Function definition different from previous definition
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 45(44,45): Expecting a declaration
*** Error 48 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 45(49,50): Expecting a (
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 45(51,52): Expecting a declaration
*** Error 28 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 45(64,65): Expecting an identifier
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 45(65,66): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 46(7,13): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 46(14,15): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 46(15,16): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 46(16,17): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 46(17,18): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 47(4,8): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 48(7,13): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 48(14,15): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 48(15,16): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 48(16,17): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 48(17,18): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 49(1,2): Expecting a declaration
*** Error 28 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 55(21,24): Expecting an identifier
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 55(29,30): Expecting a declaration
*** Error 48 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 62(4,9): Expecting a (
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 62(10,14): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 62(14,15): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 63(4,6): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 63(6,7): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 63(7,9): Expecting a declaration
*** Error 48 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 63(9,23): Expecting a (
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 63(43,44): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 63(45,46): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 64(8,14): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 64(15,16): Expecting a declaration
*** Error 48 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 64(16,19): Expecting a (
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 64(21,22): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 65(10,14): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 65(15,16): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 65(19,20): Expecting a declaration
*** Error 28 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 65(36,37): Expecting an identifier
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 65(37,38): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 68(21,26): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 68(26,27): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 69(10,14): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 69(15,16): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 69(19,20): Expecting a declaration
*** Error 28 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 69(37,38): Expecting an identifier
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 69(38,39): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 72(21,26): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 72(26,27): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 73(10,14): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 73(15,16): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 73(19,20): Expecting a declaration
*** Error 28 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 73(37,38): Expecting an identifier
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 73(38,39): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 76(21,26): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 76(26,27): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 77(8,9): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 79(8,10): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 79(10,11): Expecting a declaration
*** Error 48 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 79(11,19): Expecting a (
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 79(21,22): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 80(10,12): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 80(12,13): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 80(13,14): Expecting a declaration
*** Error 29 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 80(26,27): Function definition different from previous definition
*** Error 48 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 81(12,20): Expecting a (
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 81(26,27): Expecting a declaration
*** Error 48 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 82(12,17): Expecting a (
*** Error 48 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 82(18,26): Expecting a (
*** Error 48 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 83(12,20): Expecting a (
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 83(21,25): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 83(25,26): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 84(10,11): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 85(8,9): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 85(10,14): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 85(15,16): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 86(11,13): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 86(13,14): Expecting a declaration
*** Error 29 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 86(26,27): Function definition different from previous definition
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 87(14,16): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 87(16,17): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 87(17,18): Expecting a declaration
*** Error 28 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 87(29,30): Expecting an identifier
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 87(30,31): Expecting a declaration
*** Error 48 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 88(16,19): Expecting a (
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 88(20,21): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 88(21,22): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 89(14,18): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 89(19,21): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 89(21,22): Expecting a declaration
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 89(22,23): Expecting a declaration
*** Error 29 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 90(16,17): Function definition different from previous definition
*** Error 43 "C:\Program Files\PICC\Drivers\flex_kbd.c" Line 90(19,20): Expecting a declaration
100 Errors, 1 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Mon Aug 27 10:01:16 2012 |
