Facing problem while reading GSM modem with pic16f877a
thangapandi
PostPosted: Mon Aug 27, 2012 2:48 am     Reply with quote
in starting of "GSM modem with TTL output",modem will send RDY,+CFUN: 1,+CPIN: NOT READY like as follows
0x0d 0x0a R D Y 0x0d 0x0a
0x0d 0x0a + C F U N : 1 0x0d 0x0a
0x0d 0x0a + C P I N : N O T R E A D Y 0x0d 0x0a
Through PIC i am able to read only upto " 0x0d 0x0a R D Y ".Remaining i am not able to read.i dont know what is the problem.
baud rate i used : 9600,null modem
ALI_726
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
Re: Facing problem while reading GSM modem with pic16f877a
PostPosted: Mon Aug 27, 2012 5:21 am     Reply with quote
Hello, I have read your problem. I can help you for GSM coding and hardware issues. Feel free to ask any question or help about GSM modem.
ezflyr
PostPosted: Mon Aug 27, 2012 9:22 am     Reply with quote
Actually, this is a forum for the CCS 'C' compiler, so if your GSM modem
question is not directly related to a CCS based project then you should
not feel free to ask your questions here, but rather you should find a
more appropriate forum.
John
PostPosted: Mon Aug 27, 2012 9:32 am     Reply with quote
Actually, he is talking about having problems reading the result with a PIC (so hopefully CCS), unlike the other poster asking a GSM question.
My guess would be the input routines are not allowing for the line feed character. This is a common problem when parsing the data from modems. If you use the 'gets' function, the second return, will have an extra '0xa' at the front, making the string one character longer than expected, and the characters won't be in the locations expected.
I'd suggest two things:
1) Search the forum archives. There have been a lot of code pieces posted in the past showing approaches to this.
2) Assuming you _are_ using CCS, post the simplest possible code example showing what you are trying.
thangapandi
PostPosted: Mon Aug 27, 2012 10:26 pm     Reply with quote
I am using CCS compiler. I will post my sample code which I tried soon.
ezflyr
PostPosted: Wed Sep 05, 2012 11:21 pm     Reply with quote
Well, it looks like I was correct, this really wasn't a CCS 'C' related question after all..... No code posted, no CCS version number given, so you've been called out!
John
thangapandi
PostPosted: Thu Sep 06, 2012 2:31 am     Reply with quote
problem got resolved,code implemented as follows
getch() //0x0d
getch() //0x0a
gets() //RDY + 0x0d
getch() //0x0a
PostPosted: Thu Sep 06, 2012 2:35 am     Reply with quote
So, it was the extra line feed.
It is a common problem, with things sending line feed, plus carriage return, while gets, as implemented, only wants carriage return.
