interrupts disabled during call to prevent re-entrancy
vudt2412
PostPosted: Mon Aug 13, 2012 10:12 am     Reply with quote
Hello everyone,
CCS compiler give me a warining:
>>> warnning 216: interrupts disabled during call to prevent re-entrancy:[@PSTRINGC7_115200_62_63]
But I don't know the reason. The program can't work properly? Would you pls tell me? please help...
Idea
Douglas Kennedy
PostPosted: Mon Aug 13, 2012 11:12 am     Reply with quote
Chances are you have bloated up an isr. The rule for isr's is never never ever put printf or float in an isr. Now you might break the rule during testing but you must be aware of the time a printf or float calc blocks the isr.
Here your issue is related to string routines.
asmboy
PostPosted: Mon Aug 13, 2012 1:35 pm     Reply with quote
post your code in question???
mr_Orange
PostPosted: Wed Aug 15, 2012 3:13 am     Reply with quote
I do get the same message because I use fprintf() in the HLVDIN interrupt. I think that the compiler is warning you about the possibility that while main is using fprintf() the interrupt routine is called so it tries to start fprint() a second time while the first fprintf() is not finished. I think the interrupt will start up after finishing the first fprintf() in main() so there will be a delay in starting the interrupt routine.
Since in my case HLVDIN detects that the controller is powered down I don't bother since the fprintf() in the interrupt is executed and the program stays in the HLVDIN interrupt routine until the power is gone.
