shardul
more power consumed in sleep mode 18f25k20 |
Posted: Tue Aug 07, 2012 7:28 am |
ccs 4.120, device:-18f25k20
I'm trying to make it sleep by a simple sleep(); instruction
facing strange problem, before sleep it takes 1.2mA & after 8.41mA.
I've tried all oscillator configuration!
.h file contains following code
#include <18F25K20.h>
#device adc=10
#FUSES INTRC_IO //Internal RC Osc
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES NOLPT1OSC //Timer1 configured for higher power operation
#FUSES NOHFOFST //High Frequency INTRC waits until stable before clocking CPU
#use delay(int=1M)
#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3)
Please guide me I'm stuck since a day |
Gabriel
Posted: Tue Aug 07, 2012 8:13 am |
keep pins from foating.. set them as outputs and tie them to V+or GND.. allowing them to float will consume alot of power.
turn OFF all prehipedrals your not using... ADC, WDT, TIMERS, COMPARATORS, UART... you get the point...
changing oscillator frequencies will help you conserve power while running...
in sleep, the oscillator is off...
G. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
Posted: Tue Aug 07, 2012 8:19 am |
Gabriel has addressed the important aspects. Just a small correction, in sleep mode all oscillators except for WD and possibly 32 kKz crystal are off, digital modules aren't at risk to consume power. |
shardul
tried that too |
Posted: Tue Aug 07, 2012 8:34 am |
thanks for replying
i've tried your way before too .... no success
floating pin consume current ? idk
i have 3 empty pins which are configured as o/p and @ logic 0.... will that affect ?
also shutting down the peripherals which are/will not used.
made WDT off ... still same result
i have big doubt on Internal pullups of port b !
i didnt get much about oscillator specified in datasheet
thanks |
