zagoaristides
Joined: 08 Jul 2007 Posts: 15 Location: Cordoba - Argentina
Problem using PWM and other Port C outputs - 16f916 |
Posted: Tue Aug 07, 2012 7:13 am |
Well, I can't figure out how to make PWM and PORTC outputs work together.
This is the code
int var, i, Start_Iniciado, var_input, var_mostrar;
int1 var1;
int1 arranque_inicial;
setup_adc_ports(sAN0|sAN1|VSS_VDD);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_8); //1 ms
//setup_wdt(WDT_2304MS|WDT_DIV_16);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1); //32 ms
setup_timer_2(T2_DIV_BY_1,255,1); //15 Khz
setup_ccp1(CCP_PWM);
//set_tris_c(0b00010000); I also try fast input output
//TODO: User Code
// INICIALIZACION DE VARIABLES, SALIDAS Y ENTRADAS IMPORTANTES
output_high (PIN_OUT_STOP);
var_decremeta_cuenta_xa_1_seg = cuenta_xa_1_seg;
flag_blink_Power_LED = FALSE;
flag_blink_Stop_LED = FALSE;
flag_blink_Sensor_LED = FALSE;
flag_blink_S_Corr_LED = FALSE;
flag_STOP = TRUE;
flag_START = FALSE;
flag_Sobre_Corr = FALSE;
Start_Iniciado = FALSE;
sent_giro = sent_enroscando;
//enable_interrupts(INT_AD);
enable_interrupts (INT_EXT);
enable_interrupts (INT_TIMER1);
//enable_interrupts (INT_TIMER0);
stop();
flag_SENS_PUNTA = TRUE;
arranque_inicial = TRUE;
for(;;)
restart_wdt();
if ( flag_START == FALSE && flag_STOP == FALSE){
//pot timer
set_adc_channel (1);
delay_us(30);
timer_segs = read_adc();
delay_us(30);
var_decrementa_timer_segs = timer_segs;
//THIS IS THE GREAT PROBLEM with Output and PWM
//IF I take out this output_c code, everything works fine
if (var_BCD_timer_nums != var_BCD_timer_nums_anterior){
//var_decrementa_timer_segs--;
//var_input = input_c();
var_mostrar = var_BCD_timer_nums;
output_c(BCD_numbers[var_mostrar]);
var_BCD_timer_nums_anterior = var_BCD_timer_nums;
if (var_decrementa_timer_segs == 0 && flag_START == TRUE){
flag_STOP = TRUE;
//flag_START = FALSE;
var_mostrar = 14; // Letra t = Terminado
// Boton Stop
if (flag_STOP == TRUE || (var_veloc_motor_pote > 120 && var_veloc_motor_pote < 130)){
flag_START = FALSE;
arranque_inicial = FALSE;
stop();
if (Start_Iniciado == TRUE && ( (var_veloc_motor_pote_anterior != var_veloc_motor_pote) || arranque_inicial == TRUE ) ){
//disable_interrupts(INT_TIMER1);
if (var_veloc_motor_pote > 130){
var_veloc_motor = var_veloc_motor_pote * 2;
veloc_motor();
if (var_veloc_motor_pote < 120){
sent_giro = sent_desenroscando;
var_veloc_motor = 255 - var_veloc_motor_pote * 2;
veloc_motor();
var_veloc_motor_pote_anterior = var_veloc_motor_pote;
// Start
if (flag_START == TRUE && Start_Iniciado == FALSE && flag_STOP == FALSE && flag_SENS_PUNTA == TRUE){
flag_STOP = FALSE;
Start_Iniciado = TRUE;
output_LOW(PIN_OUT_STOP_LED);
output_HIGH(PIN_OUT_Power_LED);
flag_blink_Power_LED = TRUE;
////// Control de Sobre Corriente ///////////
if (flag_S_Corr == TRUE){
flag_STOP = TRUE;
flag_PITIDO = TRUE;
output_HIGH(PIN_OUT_S_Corr_LED);
flag_blink_Stop_LED = TRUE;
cuenta_xa_S_Corr = 0;
if (flag_S_Corr == FALSE && flag_PITIDO == TRUE){
flag_PITIDO = FALSE;
void stop (void){
int var_input, var_mostrar;
var_veloc_motor = 0 ;
veloc_motor();
output_LOW(PIN_OUT_STOP); //ENABLE of L293
flag_STOP = FALSE;
void veloc_motor (void)
if (sent_giro == sent_enroscando)
output_low(PIN_OUT_Sent_Giro);
if (sent_giro == sent_desenroscando)
output_high(PIN_OUT_Sent_Giro);
set_pwm1_duty (var_veloc_motor);
set_pwm1_duty (255 - var_veloc_motor);
output_HIGH(PIN_OUT_STOP); //el ENABLE del Integrado L293
Posted: Tue Aug 07, 2012 11:16 am |
With standard_io selected, 'input_c' says set the TRIS for the whole of port C, to input. This immediately stops the PWM (which requires the ccp pin set as an output), from working.
Choices:
1) Switch to using fast_io, and set the tris yourself.
2) Switch to using fixed_io, and set the CCP pin as an output.
3) Immedately after the input line, add 'output_drive',on the CCP pin.
zagoaristides
Posted: Tue Aug 07, 2012 12:19 pm |
Ttelmah wrote: | With standard_io selected, 'input_c' says set the TRIS for the whole of port C, to input. This immediately stops the PWM (which requires the ccp pin set as an output), from working.
Choices:
3) Immedately after the input line, add 'output_drive', on the CCP pin.
Thanks a lot, I never used that output_drive function. By the way I figured out how to make it work by making an output bit by bit, like this.
for(i = 56; i<60;i++) //PIN_C0 al PIN_C3
output_bit(i,shift_right(&var_mostrar,1, pin_C0)); |
