zagoaristides
Joined: 08 Jul 2007 Posts: 15 Location: Cordoba - Argentina
MachX Windows Seven | Windows 7 x64 -Unknown Device - URGENT |
Posted: Mon Jul 26, 2010 11:47 am |
Hello, I first wrote to CCS directly but one week later I don't have answer. I'm desperate. I can't make MachX work under Windows 7 x64 64 bits. The first time I run usb drivers the system attempts to recognize it, but after first restart of the system It never ever recognize it again. I've tried to uninstall the driver and install it again but nothing happend. Please help me beceause I really need this get to work and I can't get support from CCS. Thanks. |
spilz
Posted: Wed Aug 01, 2012 10:44 am |
hey!
I have the same problem, did you find a solution?
thanks |
kam
MachX |
Posted: Mon Aug 06, 2012 12:52 pm |
Hey splitz,
I've just installed the complete CCS system (compiler, machX) on a win7 64 bit machine. I had no issue at all.
Make sure to uninstall EVERYTHING related the CCS/MachX
Then reinstall the drivers WITHOUT inserting the MachX USB
Once you have installed everything, just plug in the USB cable to the MachX and Windows should locate the drivers just fine...
What errors do you see?
~Kam |
spilz
Posted: Mon Aug 06, 2012 1:05 pm |
Thanks for your reply.
Actually, it works now, but only on one usb port, not on the second.
I tried to re-install the driver, but it still doesn't work on the second port, "error 10".
Does it works on both for you? |
