About 25LC080b SPI eeprom on 18F4620
sindyvirgo
PostPosted: Wed May 20, 2009 10:43 pm     Reply with quote
My SPI EEPROM can't work ...
Help me, please .... Orz !!
I use CCS function of spi_write, spi_read.
I want to write an ASCII word to EEPROM and read ASCII word from EEPROM.
But it can't work...
#include "C:\Documents and Settings\Chen Yang Li\My Documents\CCS\SPI_EEPROM_4620\spi_eeprom_4620.h"
#include <stdio.h>
#include <stddef.h>
#include <stdlib.h>
#include <stdlibm.h>
#include <string.h>
#define EEPROM_SELECT  PIN_A5     //CS
#define EEPROM_CLK     PIN_C3   //CLOCK
#define EEPROM_DI      PIN_C4   //Input
#define EEPROM_DO      PIN_C5   //Output
#define EEPROM_SIZE   1024
char SPI_Data;
#int_RDA
void  RDA_isr(void)
 rs_buff = getc();
 printf("%c",rs_buff);
#int_SSP
void  SSP_isr(void)
  output_low(EEPROM_SELECT);
  spi_write(0x03);
  spi_write(0x00);
  spi_write(0x10);
  SPI_Data = spi_read(0x00 >> 8);
void initial_eeprom()
 output_high(EEPROM_SELECT);
 output_low(EEPROM_DI);
 output_low(EEPROM_CLK);
void write_ext_Enb_eeprom()
  output_low(EEPROM_SELECT);      //Select Device
  spi_write(0x06);               //Enable OP code
  output_high(EEPROM_SELECT);      //Deselect Device
  spi_write(0x02);               //write OP code
  spi_write(0x00);              //High address
  spi_write(0x10);              //Low address
  spi_write('G');               //write ASCII 'G'
 setup_psp(PSP_DISABLED);
 setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_4);
 setup_wdt(WDT_OFF);
 setup_timer_0(RTCC_INTERNAL);
 setup_timer_1(T1_DISABLED);
 //setup_timer_2(T2_DISABLED,0,1);
 //setup_timer_3(T3_DISABLED|T3_DIV_BY_1);
 //setup_vref(FALSE);
 enable_interrupts(INT_RDA);
 enable_interrupts(INT_SSP);
 setup_oscillator(OSC_8MHZ|OSC_INTRC|OSC_31250|OSC_PLL_OFF);
 printf("SPI Testing....");
 delay_ms(3000);
 initial_eeprom();
 for(;;)
     write_ext_Enb_eeprom();
     printf("%i",SPI_Data);
PostPosted: Wed May 20, 2009 11:53 pm     Reply with quote
Here is a hardware SPI driver that should work with the 25LC080B:
http://www.ccsinfo.com/forum/viewtopic.php?t=28199&start=1
You want to run the oscillator at 8 MHz. There is no reason to have
the "OSC_31250" parameter in there. Delete it.
#int_SSP
void SSP_isr(void)
spi_write(0x03);
spi_write(0x00);
spi_write(0x10);
I don't see the reason for the SSP interrupts. Use the code shown in
the link that I posted above. Delete all the INT_SSP stuff.
semmoor
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Fri Jul 27, 2012 4:04 am     Reply with quote
i tested this code didn't work
PostPosted: Fri Jul 27, 2012 4:35 am     Reply with quote
This makes no sense to me...
Why are you testing a 3 years old code of which the original poster says it doesn't work??? Confused
semmoor
PostPosted: Fri Jul 27, 2012 5:48 am     Reply with quote
No !! i didn't mean the code above, i meant the code on this link :
written by pcmprogrammer that's why i was amazed, how come a code written by pcmprogrammer can't work? it never happened before.
but i'm really sure it might be something on my circuit.
thanks ckielstra.
