Port Configuration (Digital Inputs)
carl
PostPosted: Thu Jul 26, 2012 8:16 am     Reply with quote
Hi there,
I am using a PIC18F4550.
I want configure pins RC4 and RC5 as digital inputs.
page 119 of the datasheet states
On a Power-on Reset, these pins, except
RC4 and RC5, are configured as digital
inputs. To use pins RC4 and RC5 as
digital inputs, the USB module must be
disabled (UCON<3> = 0) and the on-chip
USB transceiver must be disabled
(UCFG<3> = 1).
So how do I configure the port for digital?
Carl
TMLtech
PostPosted: Thu Jul 26, 2012 11:26 am     Reply with quote
I use in that way:
#use fast_io(0b00110000);
PostPosted: Thu Jul 26, 2012 12:58 pm     Reply with quote
I use in that way:
This answer is incorrect. Please read the CCS manual and verify your
answer before posting.
To answer the question, the USB module is already disabled upon
power-on reset, so you don't need to do it. But the USB transceiver
is enabled by default, so you need to add a line of code at the start
of main() to disable it. See the program shown below:
#include <18F4550.h>
#fuses INTRC_IO, NOWDT, PUT, BROWNOUT, NOLVP CPUDIV1
#use delay(clock=4M)
#byte UCFG = getenv("SFR:UCFG")
#bit UTRDIS = UCFG.3
int8 result;
UTRDIS = 1;    // Disable USB transceiver
   result = input(PIN_C4);
   printf("%u ", result);
carl
PostPosted: Thu Jul 26, 2012 1:19 pm     Reply with quote
Thanks PCM,
I will try it tomorrow.
Carl
