Help to read pulse width on PIC 16F684 pin
Spradecom
PostPosted: Wed Jul 25, 2012 6:14 am     Reply with quote
I am using PIC 16F684 to read pulse from optocoupler that outputs a square wave on INT pin. I am trying to write code with input frequency 100Hz.
16F684 uses crystal frequency 4MHz internal oscillator. And want to generate PWM on Pin 5 with 250Hz. Can you draft any example program ? THANKS
Mike Walne
PostPosted: Wed Jul 25, 2012 7:48 am     Reply with quote
This is a help forum, NOT a write it for you one.
Have a go yourself.
Come back when you're stuck.
Show us what you have done.
Explain what your code should do.
Explain what it does / doesn't do.
There are loads of examples provided by CCS.
Read the CCS forum guide, CCS manual, and data sheet for your PIC.
When you can demonstrate that you have made an effort, it is more than likely that someone here will offer real/valuable assistance.
Mike
bkamen
PostPosted: Wed Jul 25, 2012 8:20 am     Reply with quote
And make sure to read: http://www.ccsinfo.com/forum/viewtopic.php?t=47549
before you post.
-Ben
Spradecom
Re: Help to read pulse width on PIC 16F684 pin
PostPosted: Thu Jul 26, 2012 1:58 am     Reply with quote
I had try on this code plz can any help
unsigned int1 state;
unsigned int1 start_count;
unsigned int16 count;
unsigned int16 old_count;
unsigned int16 duty;
unsigned int16 new_duty;
unsigned int8 ramp_delay_counter;
void read_data(void);
void initialise_ports(void);
void init_variable(void);
#int_EXT
void  EXT_isr(void)
   state=0;
   state = input(PIN_A2);
   if(state   ==   0)
      start_count=1;
      start_count=count=0;
#int_TIMER0
void  TIMER0_isr(void)
   if(start_count)
      if(count < 80)
         count++;
         count=0;
      count=start_count=0;
   if(duty != new_duty)
      if(ramp_delay_counter < 5)
         ramp_delay_counter ++;
         if(duty < new_duty)
            duty ++;
         else if(duty > new_duty)
            duty --;
         ramp_delay_counter = 0;
      set_pwm1_duty(duty);
   setup_adc(ADC_OFF);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DIV_BY_16,249,1);
   setup_oscillator(OSC_4MHZ);
   setup_ccp1(CCP_PWM);
   set_pwm1_duty(0);
   setup_vref(FALSE);
   ext_int_edge(H_TO_L);
   initialise_ports();
   init_variable();
   enable_interrupts(INT_EXT);
      read_data();
      if(state   ==   1)
         old_count=count;
         start_count=0;
         count=0;
   output_float(PIN_A0);
   output_float(PIN_A1);
   output_high(PIN_A2);
   output_float(PIN_A3);
   output_float(PIN_A4);
   output_float(PIN_A5);
   output_float(PIN_C0);
   output_float(PIN_C1);
   output_float(PIN_C2);
   output_float(PIN_C3);
   output_float(PIN_C4);
   output_low(PIN_C5);
   duty=0;
   new_duty=0;
   unsigned int16 calc_duty;
   clear_interrupt(INT_EXT);
   old_count=35-count;
   calc_duty=(unsigned int16)(old_count * 48);
/*   if(calc_duty <= 51)
      new_duty=2;
      if(calc_duty >= 662)
         new_duty=1023;
         calc_duty=calc_duty-51;
         new_duty=(unsigned int16)(calc_duty * 1.54);
   new_duty=calc_duty;
Mike Walne
PostPosted: Thu Jul 26, 2012 2:44 pm     Reply with quote
You're not following temtronic's mantra, and also trying to do several things at once.
I, for one, can't follow what you're doing, I'm not going to spend hours deciphering your code.
So, simplify, simplify, simplify, when you're done, simplify some more.
Break your problem into manageable chunks, then deal with them one at a time.
Mike
