Requan
Function with IO ports as arguments |
Posted: Thu Jul 12, 2012 3:13 am |
I would like to built two function with port as argument for write and read data in port, so e.g:
#include <18F46k20.h>
#use delay(clock=20M)
#define LedOK Pin_B1
#define LedNG Pin_B0
Led(int8 *Port)
output_low(Port);
delay_us(1000);
output_high(Port);
delay_us(1000);
output_low(Port);
main()
int8*pointLedOK = LedOK;
Led(*pointLedOK);
I used pointer but i didn't work.
Where i made mistake? |
Posted: Thu Jul 12, 2012 8:27 am |
A port pin number, is just a number, not a pointer. It is also an int16, not an int8.
So:
void Led(int16 pin_number) {
output_low(pin_number);
delay_us(1000);
output_high(pin_number);
delay_us(1000);
void main(void) {
int16 pointLedOK = LedOK;
Led(pointLedOK);
while(1) ;
Also, I doubt if you will see this. The led will only be on for 1mSec.....
Requan
Posted: Fri Jul 13, 2012 7:22 am |
Thanks Ttelmah for help.
Yes You right
I made mistake instead ms I write us.
Best Regards, |
