M25p40 driver
andys
M25p40 driver
PostPosted: Wed Jul 11, 2012 7:45 pm     Reply with quote
At the link http://www.ccsinfo.com/forum/viewtopic.php?t=28445
PCM programmer said that the driver of 68hc68r2 is able to use for the m25p20.
I would like to ask if someone know any driver which is able to be used instead of m25p40 or how to modify 68hc68r2 to be used for the m25p40 component????
I would need to read from adc and use spi for writing to m25p40 memory.
PostPosted: Thu Jul 12, 2012 5:32 am     Reply with quote
I way I read that post, PCM pgmr didn't say it would work, the OP said it did....
however without real chips I can't test the driver.
As well, you don't say which PIC you're using,compiler version,etc. All of which is necessary to help you.
hth
jay
andys
M25p40 driver
PostPosted: Thu Jul 12, 2012 6:36 am     Reply with quote
I used dspic33fj128gp708 .
(How to find the compiler version?)
PostPosted: Thu Jul 12, 2012 6:56 am     Reply with quote
Easy....open up the listing(ie:programfilename.lst), it'll be on the first few lines(ie: version 4.nnn).
andys
M25p40 driver
PostPosted: Thu Jul 12, 2012 7:16 am     Reply with quote
version: 4.3.0.218
Can you help me?
andys
M25p40 driver
PostPosted: Thu Jul 12, 2012 3:01 pm     Reply with quote
No respond yet? Crying or Very sad
PostPosted: Thu Jul 12, 2012 3:45 pm     Reply with quote
You should printout the datasheets for of the devices and compare the communications information (SPI..timings...commands..etc.)
Then make a copy of the driver(do NOT alter the original driver !) and edit it to conform to the commands and timings for your device.
Then try it out on real devices.Be sure to store 'known' data, say 1-2-3 and be sure you can read it back !
Once you're sure this test data is correct, proceed with more testing, say 50-100 'known' data and confirm it is correct.
You might want to google your chip and PIC C driver code or similar to see if you get any 'hits'.
I do not write drivers without having the real hardware in my PIC test boards.
