is this ANSI acceptable or not ??? [solved] -Octal confused
asmboy
PostPosted: Wed Jul 11, 2012 2:44 pm     Reply with quote
version 4.134
CONST BYTE ok[4]={254,012,42,048}
will not compile , errors - with "numeric expected"
where as
CONST BYTE ok[4]={254,12,42,48}
DOES .... ?????
what kind of parser can't handle a leading zero ??
gaugeguy
PostPosted: Wed Jul 11, 2012 3:37 pm     Reply with quote
Wouldn't 012 be 12 Octal and not 12 decimal?
PostPosted: Wed Jul 11, 2012 4:22 pm     Reply with quote
Compile it in MSVC++ 6.0 (as a C file):
#include <stdio.h>
const unsigned char ok[4]={254,012,42,048};
It does not like illegal digits for numbers specified in Octal format (base 8):
C:\Program Files\Microsoft Visual Studio\MyProjects\Test\Test.c(8) :
error C2041: illegal digit '8' for base '8'
Error executing cl.exe.
PostPosted: Wed Jul 11, 2012 5:49 pm     Reply with quote
yup typos can bite real bad.
O000O0O0
after a few hours ohs look like zeros.....
especially in some fonts !!!
It'd be nice to have zeros with a slash forced through them.
or at least the option to allow it for us , um, older guys with bifocals !!
jay
PostPosted: Wed Jul 11, 2012 5:54 pm     Reply with quote
It's not a typo. It's just a mistake. Example:
http://stackoverflow.com/questions/8459030/whats-wrong-with-array-declaration-invalid-digit-in-octal-constant
asmboy
PostPosted: Wed Jul 11, 2012 6:22 pm     Reply with quote
thanks for the helpful explanation.
that number base had slipped from my pea brain
Very Happy Very Happy
PostPosted: Wed Jul 11, 2012 7:08 pm     Reply with quote
hmmm..not a typo...man my eyes are getting bad...still looks like a zero not a big oh to me, sigh, getting old sucks..
Last octal I did was in PDP-11 systems...back in '75...must admit it might not be 'common' anymore....
I do recall some systems allowing you to set the 'default' base for numbers entered in a program which is kinda handy.
I have used leading zeros in 3 digit decimal numbers to keep things visually aligned, making it easier to see 'funny' numbers.
gpsmikey
PostPosted: Wed Jul 11, 2012 8:34 pm     Reply with quote
I still think in octal these days -- too many hours spent hand coding 8080/Z-80 assembler. Those processors were octal in opcode design - 176 was mov A,M while 167 was the reverse - mov M,A. Interestingly enough, the instruction for MOV M,M (166) was the HALT instruction. Used to have a little cardboard slide rule for figuring the opcodes for all the instructions ... come to think of it, I probably still have it down stairs :-)
mikey
mikey
