Where can I find driver for the sensor SHT25 ?
andys
Driver For SHT75 Temperature & Humidity Sensor
PostPosted: Tue Jul 10, 2012 6:33 am     Reply with quote
Where can i find driver for the sensor SHT25????
Can i use the driver of SHT75 for the SHT25 sensor?????
PostPosted: Tue Jul 10, 2012 2:12 pm     Reply with quote
does not look that hard to write one.
is this classwork or a job offer ?
Smile Smile
got 3.3V ???
PostPosted: Tue Jul 10, 2012 5:19 pm     Reply with quote
SHT25, standard I2C interface,datasheet explains all modes,examples online....
...cutting a driver from 'scratch' for the device might take 1-2 hours...add a coffee brake or two... 4 hours tops and it's all done...
..cut and paste applicable routines or functions from similar drivers will cut the time in half.
no..I will not do the work for you since I do not have that device here to test my code and I don't send any code or drivers without testing them on real hardware here in my real shop.That's the only way I _know_ the code works.
andys
PostPosted: Tue Jul 10, 2012 5:26 pm     Reply with quote
ok, can you help me , explain to me how to do it?
This is the first time that i try to do something like this.
PostPosted: Tue Jul 10, 2012 5:30 pm     Reply with quote
ok - i suggest you adapt some example i2c code to the specs of the part.
then show what effort you expended and what you have written yourself that does not work.
if you have no clue of where to start, perhaps you have chosen the wrong career. Smile Smile
PostPosted: Tue Jul 10, 2012 7:24 pm     Reply with quote
The mfr. gives complete code in their download section, so I'd print that out for a start...
'Googling' the part number and CCS C code might get a few hits....
Also you appear to have a driver for a similar product , so simply read both datasheets (print them out..) look side by side, compare command codes, data format, etc. to see what's the same...what's not...take notes !
Usually mfrs. will make devices similar so that code will be similar. This allows everyone to take advantage of past code, common drivers, easy upgrading, etc.
I prefer to use hardcopy, allows me to easily compare information, highlight bitmaps, function tables, etc. Same hold true for breadboarding a schematic. You can highlight connections to confirm proper signal paths, grounds, etc.
It's the details like finding out you've 'crisscrossed' I2C data and I2C clock lines that show why it is important to read the datasheets, confirm pinouts, and recheck the wiring.
Also do not try to make a complete, 'sophisticated' program, just the basics, in this case say just read the data and display it....
On this forum(or the code library), PCM programmer has an I2C test program. It would be a great start....as it will confirm you've got the device attached to the I2C bus correctly. Be sure to use the correct pullup resistors (3k3 or 4k7 may be ok for the 3 volt supply you must use).
Start small and simple, make BACKUP copies of ALL programs,building on small changes or additions. Yes, you may end up with 30-40-50 versions of the program, who cares, computers have terabytes nowadays. When you get it 'up and running', then delete all but say the last 5 versions. That way you'll have a chance to go back. If you only have 1 version and keep editing it, you have very little chance to get success as you will get confused on what works, what doesn't , or any combination !!
Drivers are not that difficult, providing you take them in steps. Get the basics working, then progress to more 'options'. If, for instance, a device allows 8 bit or 12 bit data, choose the 8 bit setup, as it's easier to code and debug to confirm that it is working. Then, code a new version to setup the 12 bit mode of data. Depending on the device the command or data need to be left or right justified or even a bit mask applied to get the right data but by having the 8 bit mode working, any errors will now come from your '12 bit code'.
hth
jay
andys
PostPosted: Tue Jul 10, 2012 9:25 pm     Reply with quote
I have already start to study the driver.
a first question:
There are two define of the pins at the beginning
#define sht_data_pin PIN_D3
#define sht_clk_pin PIN_C4
These pins, are the pins of the microcontroller which will connect the sensor ????
PostPosted: Wed Jul 11, 2012 5:17 am     Reply with quote
yes.
Depending on the PIC you choose and whatever other functions you want the PIC to do, you can use that code to 'define' which pins you want the I2C device to be attached to.
Most PICs nowadays have a builtin I2C 'module' or 'peripheral' and most programmers will choose it but the CCS compiler will allow you to use any two bidirectional I/O pins for software I2C.Actually one pin, I2C_clock can be an output only,the other I2C_data needs to be bidirectional.
hth
jay
andys
PostPosted: Wed Jul 11, 2012 4:24 pm     Reply with quote
I did some changes to the driver file of SHT75 to use it for the SHT25 sensor. Because this is the first time that I did something like that I would like, someone to to check it, please.
For every change that I did I put a note ( with symbol //-----------------> at which is write the section which I read information about it). Also I put a note for each function for which I did not put a note.
SHT25 (Under test):
// Driver file for SHT75 Temperature & Humidity Sensor                       //
// ***** To initialise SHT75 sensor upon power up *****                      //
// Function : sht_init()                                                     //
// Return   : none                                                           //
// ***** To measure and caluculate SHT75 temp & real RH *****                //
// Function : sht_rd (temp, truehumid)                                       //
// Return   : temperature & true humidity in float values                    //
//***** Function to alert SHT75 *****
void comstart (void)                     //-------------------------->No change
 output_float(sht_data_pin);  //data high
 output_bit(sht_clk_pin, 0);  //clk low
 delay_us(1);
 output_bit(sht_clk_pin, 1);  //clk high
 delay_us(1);
 output_bit(sht_data_pin, 0); //data low
 delay_us(1);
 delay_us(2);
 delay_us(1);
 delay_us(1);
//***** Function to write data to SHT75 *****
int1 comwrite (int8 iobyte)
 int8 i, mask = 0x80;               // --------------------------> Why use this?the mask equal to 0X80, Changed or not ?
 int1 ack;
 //Shift out command
 delay_us(4);
 for(i=0; i<8; i++)
   if((iobyte & mask) > 0) output_float(sht_data_pin);  //data high if MSB high
   else output_bit(sht_data_pin, 0);                    //data low if MSB low
   delay_us(1);
   delay_us(1);
   mask = mask >> 1;                                    //shift to next bit
 //Shift in ack
 delay_us(1);
 ack = input(sht_data_pin);   //get ack bit
 delay_us(1);
 return(ack);
//***** Function to read data from SHT75 *****
int16 comread (void)
 int8 i;
 int16 iobyte = 0;
 const int16 mask0 = 0x0000;               //-------------------------->Why use this Changed or not ?
 const int16 mask1 = 0x0001;                //-------------------------->Why use this Changed or not ?
 //shift in MSB data
 for(i=0; i<8; i++)
   iobyte = iobyte << 1;
   delay_us(1);
   if (input(sht_data_pin)) iobyte |= mask1;  //shift in data bit     //-------------------------->Why use this Changed or not ??
   else iobyte |= mask0;
   delay_us(1);
 //send ack 0 bit
 delay_us(1);
 delay_us(2);
 delay_us(1);
 //shift in LSB data
 for(i=0; i<8; i++)
   delay_us(1);
   delay_us(1);
 //send ack 1 bit
 delay_us(1);
 delay_us(2);
 return(iobyte);
//***** Function to wait for SHT75 reading *****
void comwait (void)
 int16 sht_delay;
 delay_us(1);
 for(sht_delay=0; sht_delay<30000; sht_delay++)  // wait for max 300ms                    //--------------------------> Why needs this Changed or not ?
   if (!input(sht_data_pin)) break;              //if sht_data_pin low, SHT75 ready
   delay_us(10);
//***** Function to reset SHT75 communication *****
void comreset (void)      //-------------------------->check
 int8 i;
 delay_us(2);
 for(i=0; i<9; i++)
   output_bit(sht_clk_pin, 1);  //toggle clk 9 times   //-------------------------->The 9 times appear at sht75 section 3.4 is ano appear at sht25.
   delay_us(2);
   delay_us(2);
 comstart();
//***** Function to soft reset SHT75 *****
void sht_soft_reset (void) //-------------------------->Changed the comwrite(0x1e) to comwrite(0xFe) table 4 in Sht75 datasheet and table 6 in sht25 datasheet
 comreset();           //SHT75 communication reset
 //comwrite(0x1e);       //send SHT75 reset command
 comwrite(0xFe);       //send SHT75 reset command
 delay_ms(15);         //pause 15 ms      //--------------------------> I don not know if this is needed.
//***** Function to measure SHT75 temperature *****
int16 measuretemp (void)     //-------------------------->No change
 int1 ack;
 int16 iobyte;
 comstart();             //alert SHT75
 ack = comwrite(0x03);   //send measure temp command and read ack status
 if(ack == 1) return;
 comwait();              //wait for SHT75 measurement to complete
 iobyte = comread();     //read SHT75 temp data
 return(iobyte);
//***** Function to measure SHT75 RH *****
int16 measurehumid (void)         //-------------------------->No change
 int1 ack;
 int16 iobyte;
 ack = comwrite(0x05);  //send measure RH command and read ack status
 return(iobyte);
//***** Function to calculate SHT75 temp & RH *****
//void calculate_data (int16 temp, int16 humid, float & tc, float & rhlin, float & rhtrue)
  void calculate_data (int16 temp, int16 humid, float & tc, float & RH, float & RHi)
 float truehumid1, rh;
 //calculate temperature reading
 //tc = ((float) temp * 0.01) - 40.0;                  //-------------------------->section4.2 Sht75
tc =175.72*((float) temp/(pow(2,16)))-46.85;           //-------------------------->section6.2 Sht25  is this ok?
 //calculate Real RH reading
 rh = (float) humid;
 //rhlin = (rh * 0.0405) - (rh * rh * 0.0000028) - 4.0;   //-------------------------->section4.2 Sht75
RH=125*(rh/(pow(2,16))) -6;                          //-------------------------->section6.1 Sht25  is this ok?
 //calculate True RH reading
 //rhtrue= ((tc - 25.0) * (0.01 + (0.00008 * rh))) + rhlin; //-------------------------->section4.2 Sht75
RHi=RH((tc*17.62)/(243.12+tc))/((tc*22.46)/(272.62+tc));    //-------------------------->section6.1 Sht25 is this ok?
//***** Function to measure & calculate SHT75 temp & RH *****
void sht_rd (float & temp, float & truehumid)//-------------------------->No change
 int16 restemp, reshumid;
 float realhumid;
 restemp = 0; truehumid = 0;
 restemp = measuretemp();    //measure temp
 reshumid = measurehumid();  //measure RH
calculate_data (restemp, reshumid, temp, realhumid, truehumid);  //calculate temp & RH
//***** Function to initialise SHT75 on power-up *****
void sht_init (void)
 comreset();    //reset SHT75
 delay_ms(20);  //delay for power-up //------------------->section 3.3 at sht75
The 2 datasheets
SHT75:
http://elcodis.com/parts/2271661/SHT75.html#datasheet
SHT25:
http://elcodis.com/parts/5618489/SHT25.html#datasheet
PostPosted: Thu Jul 12, 2012 7:39 am     Reply with quote
so , how is that working for you ??
andys
PostPosted: Thu Jul 12, 2012 7:44 am     Reply with quote
I don't have test it with hardware?
Before test it with hardware, is it look like ok?
There is any way to test it without hardware?
PostPosted: Thu Jul 12, 2012 8:58 am     Reply with quote
hardware testing is the ONLY way that matters in the end.
the procedure:
do{
1- (re) design circuit
2- (re) write program
3- build || alter hardware
4- test
} while (!working);
Mike Walne
PostPosted: Fri Jul 13, 2012 2:19 pm     Reply with quote
Yes. Support that 100%.
Mike
