Clock is 4 times faster
SpoonBilly
PostPosted: Tue Jul 10, 2012 1:41 am     Reply with quote
I am using PCWHD version 4.134 and MPLAB ICD3. What puzzles me is that the clock seems to work 4 times faster. Let say if I am using baudrate 9600, I can only receive what I want at the computer at baudrate 38400 (4 x 9600). The following code should work at 23.5Hz, but it works at 94Hz (as if the crystal is 80MHz, 4 x 20MHz). What went wrong? help please~
#include <16F1823.h>
#fuses   HS,NOWDT,NOPROTECT,NOLVP
#use     delay(clock=20000000)
#use     rs232(baud=9600, xmit=PIN_A0, invert)
unsigned int16 i ;
#int_TIMER1
void TIMER1_isr()
   set_timer1(12500) ;
   i++ ;
   printf("%lu\r\n", i) ;
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_4) ;
   enable_interrupts(INT_TIMER1)          ;
   enable_interrupts(GLOBAL)              ;
   while(TRUE) ;
PostPosted: Tue Jul 10, 2012 2:01 am     Reply with quote
This is down to a new chip architecture, and will probably take CCS a while to catch up with....
If (for example), you look at the clock sources for the timer1 module (fig 21-1), you will see that the module can be clocked internally from 'Fosc', or from 'Fosc/4'. This differs from all the traditional PIC's, where the peripherals always run from Fosc/4. Similarly with the UART, the master clock feeding into the BRG (Figure 26-1), is Fosc, rather than Fosc/4.....
The CPU itself still performs instructions at the Fosc/4 rate, but all the peripheral stuff will clock at 4* the expected rate.....
SpoonBilly
PostPosted: Tue Jul 10, 2012 5:47 am     Reply with quote
and I can't use delay_us(). Is this a related issue?
PostPosted: Tue Jul 10, 2012 5:38 pm     Reply with quote
From hard experience I can attest that extended compiler,
high level function support is still quite weak for 16F15xx, 16f19xx and 16f18xx parts.
Be prepared to do some patching as you go.....
The issues you list can be solved with a bit of creative programming.
an alternative is to just use an older part if you can.
SpoonBilly
PostPosted: Wed Jul 11, 2012 3:31 am     Reply with quote
I can live with the faster clock, but what can I do to replace delay_us()?
PostPosted: Wed Jul 11, 2012 4:10 am     Reply with quote
Depends what delays you want.
I must admit, I can't find a single one of my programs, that uses 'delay_us'....
Smile
For short delays, use 'delay_cycles'. For longer delays, have a timer 'tick' interrupt, and run a countdown clock in this.
The delay problem, applies to quite a few chips, and if I remember correctly, does work OK, with shorter delays.
PostPosted: Wed Jul 11, 2012 7:07 am     Reply with quote
for your two cited issues
#use  ...  baud=2400 for 9600 actual
how does    delay_us(desired_us*4);
work ?
nailuy
Re: Clock is 4 times faster
PostPosted: Fri Oct 05, 2012 1:50 am     Reply with quote
#FUSES PLL_SW                   //4X HW PLL disabled
Put this code in Header file and all timers and function works in normal mode
Best regards...
