benni
Need help with arrays |
Posted: Tue Jul 03, 2012 9:37 am |
I want to make a tetris game in ccs but I have a problem because SOME LEDS are permanent on.
I made an array and set everything to false:
int1 Pixel[16][8] = {{0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0},{0,0,0,0,0,0,0,0}};
Then when I create the condition all Leds are on:
for(x = 0; x < 16; x++)
for(y = 0; y < 8;y++)
if(Row[x][y] == 1 || Pixel[x][y] == 1)
TurnLedOnByCoords(x+1,y+1);
The function of TurnLedOnByCoords:
void TurnLedOnByCoords(int row, int col)
if(row <= 7 || col <= 5)
if(row==1) output_high(PIN_A0);
if(row==2) output_high(PIN_A1);
if(row==3) output_high(PIN_A2);
if(row==4) output_high(PIN_A3);
if(row==5) output_high(PIN_A4);
if(row==6) output_high(PIN_A5);
if(row==7) output_high(PIN_B0);
if(col==1)output_high(PIN_D4);
if(col==2)output_high(PIN_C6);
if(col==3)output_high(PIN_D5);
if(col==4)output_high(PIN_B3);
if(col==5)output_high(PIN_C5);
delay_us(250);
if(row==1) output_low(PIN_A0);
if(row==2) output_low(PIN_A1);
if(row==3) output_low(PIN_A2);
if(row==4) output_low(PIN_A3);
if(row==5) output_low(PIN_A4);
if(row==6) output_low(PIN_A5);
if(row==7) output_low(PIN_B0);
if(col==1)output_low(PIN_D4);
if(col==2)output_low(PIN_C6);
if(col==3)output_low(PIN_D5);
if(col==4)output_low(PIN_B3);
if(col==5)output_low(PIN_C5);
This function for turning on the leds is right because I use it in another project.
I hope that someone can help me. |
Gabriel
Posted: Tue Jul 03, 2012 10:47 am |
The obvious question would be:
What is in ???
G _________________ CCS PCM 5.078 & CCS PCH 5.093 |
benni
Posted: Tue Jul 03, 2012 11:17 am |
a 0 or a 1
for example:
Code: | Pixel[0][3]=true;
Pixel[0][4]=true;
Pixel[1][3]=true;
Pixel[1][4]=true; |
When i use BYTE instead of Boolean it works but thats not the way its only true and false that i need. |
Gabriel
Posted: Tue Jul 03, 2012 12:05 pm |
Thanks for the explanation of "Pixel[][]".... which is _not_ "Row[][]".....
... sigh.
G. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
benni
Posted: Tue Jul 03, 2012 12:18 pm |
Row[][] is a bool array just ignore Row because when for example Pixel[0][5] is set to true the led in Row 1 and Col 5 Should normally be on but the problem is that everything is on then. When I use byte instead of Boolean it works so how can i do it with boolean because otherwise the array is to big and i get an error that there is no space for all variables.
I hope you understand it. |
ezflyr
Mike Walne
Posted: Tue Jul 03, 2012 3:14 pm |
I'm totally lost. I can't even start to understand what you are doing.
Please supply schematic for LEDs, shortest possible complete compilable code which CLEARLY illustrates problem, a lucid account of what does/doesn't should/shouldn't happen, and compiler version etc.
Mike |
Gabriel
Posted: Tue Jul 03, 2012 4:08 pm |
from the looks of it he is trying to drive a LED matrix ("screen")
and set each "pixel" individually...
its easier if you set each column or row a full byte and write entire columns or rows at the same time... you can address "pixels" individually as well with this byte aproach... _________________ CCS PCM 5.078 & CCS PCH 5.093 |
