18F46K22 - unknown SFR SSPCON/SSPSTAT
picnic
PostPosted: Mon Jul 02, 2012 9:19 am     Reply with quote
I've had the following 2 lines in my code since the year dot
#byte SSPCON = GETENV("SFR:SSPCON")
#byte SSPSTAT = GETENV("SFR:SSPSTAT")
Since v4.132 the compiler complains these are not valid names. Just tried V4.134 same issue, V4.130 is OK.
Have the names secretly changed or is this a bug in the compiler?
gaugeguy
PostPosted: Mon Jul 02, 2012 9:55 am     Reply with quote
This chip has 2 MSSP and 3 control registers. You need to specifiy SSPxCONy depending on which you want to access.
picnic
PostPosted: Mon Jul 02, 2012 10:28 am     Reply with quote
Thanks for that, probably a good job the compiler complains then as moving from the PIC16 to 18 probably means the register accesses being made in the code should be reviewed. Shame it allowed it to start with Wink
