acidice333
32ch multiplexer |
Posted: Wed Jun 27, 2012 1:38 pm |
18f4550 pic...
I've got this ADG731 32ch multiplexer but I cant seem to get it to work.
I'm not sure if its my programming (probably 'cause I'm not fluent in programming) or my hardware (simple breakout board)
Basically what I'm trying to accomplish is set it to ch13 (pin48 on ADG) so A0 (pic) read from D (pin43 on ADG731)
Ive got something like this and it is probably wrong. I need to use software SPI.
sync = c0
din = c1
clk = c2
#use spi(do=pin_c1,clk=pin_c2,enable=pin_c0,enable_active=0,mode=2,bits=8)
setup_adc_ports(AN0);
spi_xfer(0x00001100); //select ch13
while(true) {
set_adc_channel(0);
delay_us(50);
adc = read_adc();
lcd_gotoxy(2,2);
printf(lcd_putc,"a0=%3u ", adc);
I have ch13 connected to 5v so I can see if my ADC reading works or not but it doesn't. Yes A0 is working, verified by gnding and 5v (0 / 255) |
Posted: Wed Jun 27, 2012 2:55 pm |
You didn't show your #fuses or #use delay(). So, I made a test program
with those things and I can now see clock, data, and enable pulses on
my oscilloscope. It's doing SPI mode 2:
#include <18F4550.h>
#fuses INTRC_IO,NOWDT,PUT,BROWNOUT,CPUDIV1
#use delay(clock=4M)
#use spi(DO=pin_c1,CLK=pin_c2,enable=pin_c0,enable_active=0,mode=2,bits=8)
spi_xfer(0x55);
delay_us(100);
acidice333
Posted: Wed Jun 27, 2012 8:24 pm |
Figured out my problem
I had the bits in the wrong order and I was using 0x0 instead of 0b0 |
