Error 117 Improper use of a function identifier
Rikims90ls
PostPosted: Thu Jun 21, 2012 4:54 pm     Reply with quote
Hello this is my error line can you help me? thank you so much
and the error is:_
*** Error 117 "Main.c" Line 92(1,2): Improper use of a function identifier
PostPosted: Thu Jun 21, 2012 6:27 pm     Reply with quote
Please read the Sticky PIC101....
We can help but need to know PIC type, compiler version and more of your program.
The error can be from several sources....trying to use a function that the PIC doesn't have,an old or buggy compiler version,etc.
Also the error might be from some code several lines before the line you think the error is caused by( happens all the time.....)
PostPosted: Fri Jun 22, 2012 1:35 am     Reply with quote
One 'classic', would be if you have created your own function, called perhaps T1_Internal (remember compiler defaults to case insignificant mode. Something a few lines before is the most likely thing though.
jeremiah
PostPosted: Fri Jun 22, 2012 6:31 am     Reply with quote
Another possible issue depends on which compiler/chip you are using I assume. For example, in PCWHD on a PIC24, you would use setup_timer1() instead.
