Generating 50Hz by calling Timer0 Interrupt
karimpain
View user's profile Send private message AIM Address MSN Messenger ICQ Number
PostPosted: Tue Jun 19, 2012 5:42 pm     Reply with quote
Hello Everybody!
I want to generate a 50hz signal using timer0, and I want to vary the duty cycle of the signal from 1ms to 2ms(servo control). I didn't test it, so I want to take in consideration all of your opinions because really I didn't understand timer0 so much, this is the code:
#include <16F877a.h>
//#device adc=10
#Fuses HS,NOPROTECT,NOWDT,NOLVP
int32 x=0;
#int_timer0
void timer0_isr()
x=x+1;
if(x>2500)
  output_low(pin_b6);
  if(x<2500)
  output_high(pin_b6);
if(x==50000) //each 50000 counts equal 20ms
x=0;//reset count each 20ms
set_tris_b(0x00);
setup_timer_0(rtcc_internal | rtcc_div_2);
set_timer0(255);//         interrupt will called each 0.4us
enable_interrupts(global);
enable_interrupts(int_timer0);
Thax 4 reading !!
PostPosted: Tue Jun 19, 2012 6:03 pm     Reply with quote
50 Hz software PWM using Timer0:
http://www.ccsinfo.com/forum/viewtopic.php?t=37807&start=3
Servo examples using the CCP module in Compare mode:
http://www.ccsinfo.com/forum/viewtopic.php?t=34560&start=22
http://www.ccsinfo.com/forum/viewtopic.php?t=44328
Mike Walne
PostPosted: Wed Jun 20, 2012 3:02 pm     Reply with quote
You don't tell us how many steps you want from 1ms to 2ms.
Mike
