micman Guest
Conversione HEX -> DEC |
Posted: Mon Nov 25, 2002 10:54 am |
Dear all,
As I can convert a HEX number in DEC number with CCS:
example:
int16 risultato; // HEX
int8 dec0; //DEC 0 //LSB
int8 dec1; //DEC 1
int8 dec2; //DEC 2
int8 dec3; //DEC 3
int8 dec4; //DEC 4 //MSB
risultato = 0x36F8 // example! HEX = 0X36F8
/*********** routine??? convert HEX (risultato) -> DEC (decx)
void convertHEX_DEC(int16 risultato)
????? //HOW FUNCTION CONVERT HEX risultato in DEC?????
dec0 = 2 //LSB
dec1 = 7
dec2 = 0
dec3 = 4
dec4 = 1 //MSB
HOW?
THANKS!
___________________________
Original Post ID: 9395 |
R.J.Hamlett Guest
Re: Conversione HEX -> DEC |
Posted: Mon Nov 25, 2002 11:29 am |
:=Dear all,
:=As I can convert a HEX number in DEC number with CCS:
:=example:
:=int16 risultato; // HEX
:=int8 dec0; //DEC 0 //LSB
:=int8 dec1; //DEC 1
:=int8 dec2; //DEC 2
:=int8 dec3; //DEC 3
:=int8 dec4; //DEC 4 //MSB
:=risultato = 0x36F8 // example! HEX = 0X36F8
:=/*********** routine??? convert HEX (risultato) -> DEC (decx)
:=void convertHEX_DEC(int16 risultato)
:=????? //HOW FUNCTION CONVERT HEX risultato in DEC?????
:=dec0 = 2 //LSB
:=dec1 = 7
:=dec2 = 0
:=dec3 = 4
:=dec4 = 1 //MSB
:=HOW?
It allready is....
Numbers are stored in binary internally (not hex or decimal). when you use the form:
risultato = 0x36F8;
The variable contains the number in binary, not hex. If you want the individual digits (as you show in your text), then:
byte out_string[6];
int count=0; //only needed for integer return
sprintf(out_string,"\%lu",risultato);
will result in out_string[0] containing '1' (in ASCII), out_string[1] containing '4', and so on. If you want the numeric values (as opposed to the string values), then you can use:
while (out_string[count]!=0) {
out_string[count]=out_string[count]-0x30;
count++;
Remember however at this point, you can no longer use the test for '0' to find the end of the string, but have to use the 'count' value to know how many digits there are.
Alternatively, if you want a 'DIY' version, and want to ensure that DEC4 allways contains the MSB digit for the five digit value, then:
DEC4=risultato/10000;
risultato=risultato \% 10000;
DEC3=risultato/1000;
risultato=risultato \% 1000;
DEC2=risultato/100;
risultato=risultato \% 100;
DEC1=risultato/10;
DEC1=risultato \% 10;
Original Post ID: 9398 |
micman Guest
Posted: Mon Nov 25, 2002 12:02 pm |
Thanks!!!
:=:=Dear all,
:=:=As I can convert a HEX number in DEC number with CCS:
:=:=example:
:=:=int16 risultato; // HEX
:=:=int8 dec0; //DEC 0 //LSB
:=:=int8 dec1; //DEC 1
:=:=int8 dec2; //DEC 2
:=:=int8 dec3; //DEC 3
:=:=int8 dec4; //DEC 4 //MSB
:=:=risultato = 0x36F8 // example! HEX = 0X36F8
:=:=/*********** routine??? convert HEX (risultato) -> DEC (decx)
:=:=void convertHEX_DEC(int16 risultato)
:=:=????? //HOW FUNCTION CONVERT HEX risultato in DEC?????
:=:=dec0 = 2 //LSB
:=:=dec1 = 7
:=:=dec2 = 0
:=:=dec3 = 4
:=:=dec4 = 1 //MSB
:=:=HOW?
:=It allready is....
:=Numbers are stored in binary internally (not hex or decimal). when you use the form:
:=risultato = 0x36F8;
:=The variable contains the number in binary, not hex. If you want the individual digits (as you show in your text), then:
:=byte out_string[6];
:=int count=0; //only needed for integer return
:=sprintf(out_string,"\%lu",risultato);
:=will result in out_string[0] containing '1' (in ASCII), out_string[1] containing '4', and so on. If you want the numeric values (as opposed to the string values), then you can use:
:=while (out_string[count]!=0) {
:= out_string[count]=out_string[count]-0x30;
:= count++;
:=Remember however at this point, you can no longer use the test for '0' to find the end of the string, but have to use the 'count' value to know how many digits there are.
:=Alternatively, if you want a 'DIY' version, and want to ensure that DEC4 allways contains the MSB digit for the five digit value, then:
:=DEC4=risultato/10000;
:=risultato=risultato \% 10000;
:=DEC3=risultato/1000;
:=risultato=risultato \% 1000;
:=DEC2=risultato/100;
:=risultato=risultato \% 100;
:=DEC1=risultato/10;
:=DEC1=risultato \% 10;
:=Best Wishes
Original Post ID: 9402 |
