How to configure SFRs?
Darkforces
PostPosted: Wed Jun 13, 2012 9:10 am     Reply with quote
Hi people!
I need to use RC4 and RC5 as digital I/O on my board, but I can't disable USB transceiver, cause I can't change the necessary bits on the SFR bank using C language. Even with assembly by directive #asm and #endasm, I try change by this way:
#asm
 bcf 0xF6D,3 // UCON<3>
 bsf 0xF6F,3  // UCFG<3>
#endasm
But, fail! The pin_C4 and pin_C5 it isn't working like digital I/O.
What can I do?
Bye!
dyeatman
PostPosted: Wed Jun 13, 2012 9:38 am     Reply with quote
It would be nice if you told us which PIC...
Google and Forum Search are some of your best tools
Darkforces
PostPosted: Wed Jun 13, 2012 9:42 am     Reply with quote
I'm using PIC18F4550
Thanks!
PostPosted: Wed Jun 13, 2012 9:44 am     Reply with quote
Precisely.
On most of the USB PIC's, the pins can only be used as digital _inputs_. A few of the more sophisticated chips do allow them to be used as outputs, but I can't think of any with the USB on C4, and C5, where this applies.
If you don't enable USB, the driver is off by default. You can read from the pins on a 18F4550 for example, fine.
Darkforces
PostPosted: Wed Jun 13, 2012 10:04 am     Reply with quote
Ok! It's true only input :( !!!
Thanks!
