Using Timer1 of 16F877A to count seconds
Patronus
PostPosted: Tue Jun 12, 2012 10:48 am     Reply with quote
I want to count seconds using timer1 of 16F877A. I used 4 as the prescaler. So the number of interrupts per second = 20000000/(4x4x65536).
To check whether this works, I wrote the following code.
#include <16F877A.h>
#device adc=10
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOCPD                    //No EE protection
#FUSES NOWRT                    //Program memory not write protected
#define INTS_PER_SECOND 19         // (20000000/(4*4*65536))
int int_count;         // Number of interrupts left before a second has elapsed
int16 seconds = 0;
void setTimer()
   OUTPUT_HIGH(PIN_B5);
   int_count=INTS_PER_SECOND;
   set_timer1(0);
   setup_timer_1(T1_INTERNAL | T1_DIV_BY_4);
#int_timer1
void clock_isr() {
    if(--int_count==0)
      ++seconds;
   setup_adc_ports(AN0);
   setup_adc(ADC_CLOCK_DIV_32);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256);
   setup_vref(FALSE);
   enable_interrupts(INT_RTCC);
   OUTPUT_B(0);
   SET_TRIS_B(10000000);
setTimer();
   while(seconds==1)
         OUTPUT_HIGH(PIN_B1);
But I can't see PIN_B1 becoming high when a second is elapsed.
I used this very same code to count seconds using timer0 and it worked.
Can someone please tell me what's wrong here?
"Silence is argument carried out by other means"
Gabriel
PostPosted: Tue Jun 12, 2012 11:07 am     Reply with quote
you never reset "seconds"... so in order for this to happen:
   while(seconds==1)
you will have to wait 254 seconds... EDIT: its a 16bit variable... so 65534 (18+hours)
and then... even when it does happen again... you wont notice.. because you never bring PIN_B1 back low...
as a word of advise... leave TRIS alone... delete that line.
G
CCS PCM 5.078 & CCS PCH 5.093
Gabriel
PostPosted: Tue Jun 12, 2012 11:11 am     Reply with quote
#int_timer1
void clock_isr() {
    if(--int_count==0)
      TOGGLE_PIN(PIN_B1)                <------------- that would be better.
if your timing is correct... you should se a ~1Hz output signal on B1.
PostPosted: Tue Jun 12, 2012 11:35 am     Reply with quote
Where is your #int_rtcc routine ?
What's the default number base used by the C language ?
Patronus
PostPosted: Tue Jun 12, 2012 11:51 am     Reply with quote
Gabriel,
Thanks for the reply.
yeah, checking it inside isr is better. Anyway I don't get a 1Hz output signal..
When my program runs, at the beginning timer is set and when number of interrupts that occurred becomes 19, the variable "seconds" should increment from 0 to 1.
What's wrong with the logic there? Why 254 seconds?
PCM Programmer,
I'm sorry, I just used the code that I used to check timer0 and that's why those lines are still there. As I know the least significant bit is for B0.
Patronus
PostPosted: Tue Jun 12, 2012 12:05 pm     Reply with quote
Hello PCM Programmer... if I either add #int_rtcc routine or remove
lines, the code works..
That was the problem I guess..?
Thanks a lot..
Gabriel
PostPosted: Tue Jun 12, 2012 12:27 pm     Reply with quote
Because the statement :
   while(seconds==1)
will only happen when seconds = 1.
assume Seconds is =1 ... it goes into the while loop...
your timer keeps going... you have 19 more interrupts and then... seconds becomes 2... then 3 then 4 and so on... only when it overflows and flips over to 0 you will be able to go from 0 to 1... thus the statement will only execute ONCE every "size of Seconds variable" .. in this case its int16 so 65534 times...
Edit:
and like i said ... when it finally does happen... you wont notice it becase PIN_B1 is already high from the last time it did happen.... toggle the pin or set it low after some time before the next time seconds = 1.
Patronus
PostPosted: Tue Jun 12, 2012 12:49 pm     Reply with quote
Gabriel, anyway I should be able to see the first time it happens right? The problem was that I couldn't see that happening. Now after doing what I've mentioned in previous reply, I can see it happening.
PostPosted: Tue Jun 12, 2012 1:05 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=47355&highlight=binary&start=5
Patronus
PostPosted: Tue Jun 12, 2012 1:31 pm     Reply with quote
I'm sorry... I haven't understand the question..
Bad mistake. I'll be more careful.
