Using Both Usart Problem With "modbus.c"
debi
PostPosted: Tue Jun 12, 2012 12:35 am     Reply with quote
We use "modbus.c" driver for PIC1867J10 with single usart(only RDA). Now we want to communicate double uart(RDA-RDA2 both) with "modbus.c" driver. Is it possible, how?
RF_Developer
Tricky....
PostPosted: Tue Jun 12, 2012 2:25 am     Reply with quote
Modbus.c ues more than one resource. The problem is not just the UARTs, its the timer(s?) modbus.c uses in RTU mode. I strongly suspect that modbus.c was written to be a highlander - there can only ever be one.
I assume your application has two or more Modbi, on one of which this code will be a slave, while on the other it is the master. Maybe some kind of Modbus repeater/extender? If so I think you are going to have to delve deep into modbus.c and sort it out for yourself. You'll have to make two versions of its control/data structures, and sort out the timer usage. Its certainly not a case of setting a natty flag and away you go.
RF Developer
