Masaya Tanaka
Behavior after wake up from sleep mode |
Posted: Fri Jun 08, 2012 8:37 am |
Hi All,
I try to sleep mode on PIC18F46K22.
I can't understand why debug messages are different between following 2 codes when INT0 interrupt occurred.
code 1:
#INT_EXT
void int_ext_isr()
clear_interrupt(INT_EXT);
fprintf(DEBUG, "Interrupt EXT\r\n");
enable_interrupts(INT_EXT);
enable_interrupts(global);
ext_int_edge(H_TO_L);
fprintf(DEBUG, "Enter Sleep Mode \r\n");
REGSLP = 1 ;
IDLEN = 1;
Sleep();
fprintf(DEBUG, "run this line\r\n");
RESULT DEBUG MESSAGE
Enter Sleep Mode
Interrupt EXT
run this line
Enter Sleep Mode
Interrupt EXT
run this line
Enter Sleep Mode
code2:
#INT_EXT
void int_ext_isr()
REGSLP = 1 ;
IDLEN = 1;
Sleep();
setup_oscillator( OSC_16MHZ );
Enter Sleep Mode
Interrupt EXT
Enter Sleep Mode
Interrupt EXT
Enter Sleep Mode
Please let me know why code 2 does not run the line 'fprintf(DEBUG, "run this line\r\n");'
Thanks |
Posted: Fri Jun 08, 2012 6:07 pm |
Post the #include for the PIC, #fuses, #use delay(), and #use rs232()
lines for your program, so I can compile it.
Also post your CCS compiler version.
If you do that, I can test it in hardware on Sunday. I'm not really going
to look at it any more today. On Sunday I can do it, though. |
Masaya Tanaka
Posted: Mon Jun 11, 2012 4:24 am |
Dear PCM programmer,
Thank you for your reply!
Sorry, my reply became slow...
#fuses, #use delay(), and #use rs232():
#FUSES LP //Low power osc < 200 khz
#FUSES WDT_NOSLEEP //Watch Dog Timer, disabled during SLEEP
#use delay(internal=32khz)
#use rs232(baud=300, parity=E, stop=1, xmit=PIN_B5, bits=8, restart_wdt, stream=DEBUG, errors)
CCS compiler version : PCWH Compiler (Version 4.112)
Thanks |
Posted: Mon Jun 11, 2012 7:06 am |
You do realise, that if the second version _does_ run the line, you'll probably never see anything?. Your code is setup to use the UART at 300bps, with the clock running at 32KHz. You then change the oscillator to 16MHz. The serial will run 500* faster (150000bps). Now, depending on the UART, this will either display a single 'garbage' character, or be ignored completely as a framing error.
