thenr.
18F4550 and LCD Analogic System |
Posted: Mon Jun 04, 2012 5:58 pm |
Hi guys, I need your help.
When I project a analogic system, using the pic 16f877A the value which shows at LCD is like 4,54V. But when I change for 18F4550 the value which shows is like 4V 5V. This way I can´t have precision, this is a part of the program.
ADC=10bits
delay_ms(10);
set_adc_channel(0);
delay_us(10);
x=read_adc();
x=x*0.004887585532746823069403714565;
this part belongs to LCD.
#define LCD_DATA_PORT getenv("SFR:PORTd")
#define LCD_ENABLE_PIN PIN_D2
#define LCD_RS_PIN PIN_D0
#define LCD_RW_PIN PIN_D1
#define DATA0 PIN_D4
#define DATA1 PIN_D5
#define DATA2 PIN_D6
#define DATA3 PIN_D7
#include "lcd.c"
Sorry about my English.
Can anybody help me ? |
Joined: 01 Jul 2010 Posts: 9163 Location: Greensville,Ontario
Posted: Mon Jun 04, 2012 6:03 pm |
1.. This line..
you really don't need nor will the compiler use that precision !!
2. what is 'x' declare as int8, int16, float ???
3. you should show us the whole program as well as the compiler version. |
thenr.
Posted: Mon Jun 04, 2012 6:24 pm |
The compiler is PCWHD 4.114
x,v = int16
Follow the whole program.
#include <18F4550.h>
#device adc=10 // seta precisao em 1023
#FUSES XT //Crystal osc <= 4mhz for PCM/PCH , 3mhz to 10 mhz for PCD
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PUT //Power Up Timer
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES NOLPT1OSC //Timer1 configured for higher power operation
#FUSES PLL12 //Divide By 12(48MHz oscillator input)
#FUSES CPUDIV4 //System Clock by 4
#FUSES USBDIV //USB clock source comes from PLL divide by 2
#FUSES VREGEN //USB voltage regulator enabled
#FUSES ICPRT //ICPRT enabled
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8
#include "lcd.c"
int16 x;
int16 v;
setup_adc_ports(AN0_TO_AN2|VSS_VDD); //portas AN0, AN1 e AN2 como analógicas
setup_adc(ADC_CLOCK_DIV_2);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_16); //
setup_timer_1(T1_INTERNAL|T1_DIV_BY_4); //
setup_timer_2(T2_DIV_BY_16,62,1); //
setup_vref(FALSE);
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
// TODO: USER CODE!!
LCD_init(); // chama a funcao do LCD, sem essa funcao o LCD nao
// escreve nada
while(1){
delay_ms(10);
set_adc_channel(0);
delay_us(10);
x=read_adc();
delay_ms(10);
set_adc_channel(1);
delay_us(10);
v=read_adc();
v=v*0.004887585532746823069403714565;
//printf(lcd_putc,"\r\n%ld %ld",v,x);
printf("\r\n%lu:%lu",v,x);
//printf(lcd_putc,"\nSUCESSO X");
printf(lcd_putc,"\r\n%lu:%lu",v,x);
Mike Walne
Posted: Tue Jun 05, 2012 3:29 am |
The PIC is doing what you're telling it.
When you multiply by 0.004887585532746823069403714565 you are effectively dividing by ~200.
Your maximum ADC value is 1023.
Your variables x and v are both integers so can only have the values 0,1,2,3,4 & 5.
If you want to display the range say 0.000V to 5.000V, convert your variables to mV rather than V. Then print thousands digit, decimal point, remaining digits.
Mike |
thenr.
Posted: Tue Jun 05, 2012 9:18 am |
I just changed the variables x and v for FLOAT.
Now I have the precision what I hoped.
Thank you !! |
