fprintf to a text file
tepes
PostPosted: Mon Jun 04, 2012 7:15 am     Reply with quote
can anyone give me an example of how to to print the data from the PIC in to a text file? something like bellow...
FILE * pFile;
   pFile = fopen ("myfile.txt","w");
   for (n=0 ; n<100 ; n++)
     fprintf (pFile, "%d ",n);
   fclose (pFile);
Thank you very much!
Gabriel
PostPosted: Mon Jun 04, 2012 9:45 am     Reply with quote
Hi...
where would such file be?
SD card?
on a host PC?
Programing on a PIC is not like programing C++ on a PC where you just print to file.
the easiest way is get an "Open Log" set you back ~25 bucks... does all you want.
CCS PCM 5.078 & CCS PCH 5.093
PostPosted: Mon Jun 04, 2012 9:49 am     Reply with quote
or buy an FTDI Vinculum based USB flash drive module for same money +-
SUPER easy to create files,save data,etc. and 100% PC compatible !
tepes
PostPosted: Tue Jun 05, 2012 1:10 am     Reply with quote
I needed the .txt file to be on a computer and to fprint in to it by using RS232! But instead I print the data to hyper terminal now, and then I copy the data to a .txt file and then I use a C++ program to create a new file where the data is formated the way I need! It takes a litle more time but I obtain what I need!
PostPosted: Tue Jun 05, 2012 1:45 am     Reply with quote
First, forget fprintf. This is designed for talking to a serial stream in the PIC, or a open file on the PC, and isn't the tool needed here.
On the PIC, with CCS, 'printf', is a generic output tool, able to route it's output to _any_ output routine using the syntax:
printf(routine_to_use,"what you want to send");
If you have a file open on an SD card, using the fat.h library, this offers 'fatputc', allowing you to write a character to this file. So you can use this as the output routine for printf, and write the text to the file. Obviously open first, flush & close when finished.
This then puts the data (text or binary), sequentially into the selected file.
Gabriel
PostPosted: Tue Jun 05, 2012 8:09 am     Reply with quote
.... you can set hyperterminal to receive/capture a text file.
so basically what ever you see printed in hyperterminal is saved to a TXT file...
its a standard feature of Hyperterminal.
You can set your PIC to output your data in the format you want.
I did this for a data logger i was building a while back.
Each line the pic printed was
ADCvalue1, Year, Month, Day, Hour, Min \n\r
ADCvalue2, Year, Month, Day, Hour, Min \n\r
ADCvalue3, Year, Month, Day, Hour, Min \n\r
ADCvalueN, Year, Month, Day, Hour, Min \n\r
and then i could easily import data to Excel as it was a comma delimited text file.
tepes
PostPosted: Wed Jun 06, 2012 3:40 am     Reply with quote
Thank you all for your help!
