Fonts to graphic display
opvini
PostPosted: Mon May 28, 2012 3:42 pm     Reply with quote
Hi everbody.
Where I found fonts to graphic display, in hexadecimal? Can I convert one font from my computer to the hex?
Thanks!!!
opvini
PostPosted: Mon May 28, 2012 3:53 pm     Reply with quote
I found this software: http://www.mikroe.com/eng/products/view/683/glcd-font-creator/
do you know others?
PostPosted: Tue May 29, 2012 12:22 am     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=44497
ezflyr
PostPosted: Tue May 29, 2012 6:44 am     Reply with quote
I used GLCD Font Creator, and found it to work pretty well. If I recall, it will generate code in a number of language/compiler formats, but none were 100% compatible with CCS 'C', so a slight hand edit was necessary. This was just syntax, however, not content!
Also, creating the new font data is generally the easy part of the exercise. Chances are that you'll need to write a new routine to display this new font on the GLCD. This is certainly true if the new font is bigger than the 5x7 fonts found in the CCS library.
John
