how to design temperature, humidity and pressure data logger
Olumuyiwa
PostPosted: Mon May 28, 2012 6:08 am     Reply with quote
Anybody with an idea should please help me out.
PostPosted: Mon May 28, 2012 1:41 pm     Reply with quote
You don't give any specs for the logger !
temperature ??? *C, *F, accuracy, resolution, bits, speed, probe distance ????
humidity ??? range, bits, etc....
pressure ??? range, PSI, mB , ????
logger ??? samples ?? frequency, data storage amount, ????
PIC type ???
MMI ?? keypad, PC link, touchscreen, LCD (2x16, 4x20), ???
I can think of 100-130 valid questions to ask you BUT you must supply us with some 'reference' point of basic 'operation' of this logger.
If you're a beginner, I'd strongly suggest using and FTDI Vinculum based USB flashdrive interface to store the data as it's a simple, easy to use hardware. You can be storing data in an evening or two.
This project should be broken down into 4 or 5 'units'.
0) get a PIC and RTC (ds1307) up and running, display date/time on LCD.
1) get data storage up and running using 'dummy data'
2) get the temperature sensor/logging going.
3) get the humidity sensor/logging going.
4) get the pressure sensor/logging going.
Just a start.....if you can program C, getting a PIC to do all this should take 1 week's effort.
