PIC to PIC Display data transfer
ze.vana
PostPosted: Sat May 26, 2012 6:44 am     Reply with quote
Hi people
that is a simple example of data transfer PIC to PIC using small and cheap PICs. Maybe this would be useful for beginners like me!
send.c
#include <16f628a.h>
#fuses INTRC_IO, NOLVP, NOWDT, PUT, BROWNOUT
#use delay (clock=4M)
#use rs232(baud=9600,XMIT=PIN_B2,RCV=PIN_B1,bits=8)
//#include "ds18b20.c"
byte send[3];
#define sreset (pin_b0)//RB0 ->- PIN1 MLCR 16F876 (resets display)
int8 div;
int8 temp=15;//temperature
int8 hrs=7,min=22;
void send_dat(void)
  int i;
  for (i=0; i<3; ++i)//1° RODA O I 10 VEZES
  putc(send[i]);
  int1 powerup;
  set_tris_a(0x00);   //DQ PIN_a4
  set_tris_b(0b00111000); //RB1 RB2  Rx/tx) / RB0 ->- PIN1 MLCR 16F876
  output_low sreset;div=0;
  powerup=false;
  while(true)
   //   ds1307_get_time(hrs,min,sec);
   output_toggle(pin_b3);//it's working!
   send[0]=hrs; send[1]=min; send[2]=temp;
   div++;
   if(!powerup && div >=10) { powerup=true; output_high sreset;} //RB0 ->- PIN1 MLCR 16F876
   if(powerup && div >10) {send_dat();  div=0; }
//RESET is to synchronize data transfer during initialization.
// Put a 10K resistor from pin1 F876 to VDD 5V      //
// to VDD                                                            //
// |      RB0  |6-----------1|MCLR    B0|- A| DIS-  | //
// |  F628     |                   |  F876   B1|- B|PLAY  | //
// |    X RB2|8----------18|C7 RX    B2|- C|         | //
// |              |  TXD->        |           B3|- D|         | //
Receive.c
#include <16F876a.h>
#device ADC=10
#fuses XT, NOLVP, NOWDT, PUT, BROWNOUT
#use rs232(baud=9600,XMIT=PIN_C6,RCV=PIN_C7,bits=8)
int16 div;
int hrs,min;
int hor4,hor3,hor2,hor1;
int temp;
int var2=0, var1=0;
int8 scan,div2;
#include "display.c"
byte receiv[3];
#INT_RDA
void rda_isr()
  int i;
  for (i=0; i<3; ++i)//receive 3 datas
  {                 //0 is the first
   receiv[i]=getc();
hrs=receiv[0]; min=receiv[1]; temp=receiv[2];
void select(void)
if (div <4000 )//show hours
   dig4=hor4;//dez hora
   dig3=hor3;//unid hora
   dig2=hor2;//dez minuto
   dig1=hor1;//unid minuto
if(div >2000 )//show degrees
              dig4=var2;    //dezena de graus
              dig3=var1;   //unidade de graus
              dig2=10;    //grau Simbolo
              dig1=11;//11= zero off
div++;
if(div >4000)  div=0;
void convert(int valor)//temperature
     var2=valor/10;            // 45 / 10=4
     var1=valor -(var2 * 10); // 45 -(4 x 10)=5
 enable_interrupts(global);
 enable_interrupts(INT_rda);
 set_tris_a(0x01);
 set_tris_b(0x00);
 set_tris_C(0b10000000 );
 div=0; div2=0; scan=100; //display time -> delay_ms(scan)
while (true)
  hor4=hrs/10;             //ex.: 23 /10      =2
  hor3=hrs -(hor4 * 10);  //      23 -(2 x 10)=3
  hor2=min/10;           // ex.:  45 / 10     =4
  hor1=min -(hor2 * 10);//      45 -(4 x 10)  =5
  convert(temp);
  mostra();//Display
  select();
Display.c
////////////////////////////// display moto
//display PIC 16f876a       // I use it on my Byke
//B0 A         C0 K1        // to show time and degrees
//B1 B         C1 K2        //
//B2 C         D2 K3        //
//B3 D         D3 K4        //
//B4 E                      //
//B5 F                      //
//B6 G   B7 NOT USED        //
 struct cont_pins
int data:4;//digitos
} cont;
#byte cont = 7   // 7 is the portc address.
byte CONST seg[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0b1100011,0b0000000,0b1000000};
int dig4=0,dig3=0,dig2=0,dig1=0;  //     10=degree symbol  11=zero_off 12=negative signal
void mostra(void)
 output_b(seg[dig4]);
 cont.data=0b1110;//1  k4,k3,k2,k1
   delay_us(scan);
 cont.data=0b1111; //Apaga display.
   delay_us(10);
 output_b(seg[dig3]);
 cont.data=0b1101;  //2
   delay_us(scan);
   delay_us(scan);
output_b(seg[dig2]);
 cont.data=0b1011;//4
  delay_us(scan);
  delay_us(scan);
 output_b(seg[dig1]);
 cont.data=0b0111;//8
  delay_us(scan);
 delay_us(scan);;
dyeatman
PostPosted: Sat May 26, 2012 8:15 am     Reply with quote
Thank you ze, I think this can be helpful to some of the upcoming "newbies".
However, a couple of suggestions:
1. Add comments at the start of the program with a description of how the
PICS are connected and any other useful info.
2. Clean up and post in the Code Library for everyone.
These types of contributions are a help to all. Thanks for your efforts!
Google and Forum Search are some of your best tools!!!!
